Idle control valve
Old Oct 3, 2001 | 08:11 AM
2fcknfst's Avatar
Default Idle control valve
How does one adjust/control the idle control valve?
I need to adjust it so I can stop my idle dwell.
Anyone?
Old Oct 3, 2001 | 08:15 AM
sgT's Avatar
sgT
Default Re: Idle control valve (2fcknfst)
with a hondata.
otherwise i know of no way to control it.
Old Oct 3, 2001 | 08:16 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
You can't. It's done by the ECU.
It may have just gone bad, but I've heard of people fixing them by taking it off and putting it back together.
Edit: It can be set by anyone with one of those handheld computers they use on your car. All dealers and most shops should have one. Those things are pretty sweet, I want one.
[Modified by newt2, 9:20 AM 10/3/2001]
Old Oct 3, 2001 | 08:23 AM
2fcknfst's Avatar
Default Re: Idle control valve (newt2)
No, it is acting up after I changed the TB out...
It is dwelling at around 25-3000rpm. Sometimes it hangs there for a couple of minutes.
Very puzzling...
Old Oct 3, 2001 | 08:54 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Vacum leak. Get a new TB gasket.
Edit: My car was doing the exact same thing last month. Mine turned out to be a cracked gasket between the blower and the manifold, but the behavior is the same.
To confirm stick a rag in your TB (with the valve closed obviously). I'll bet the car will still run.
[Modified by newt2, 9:56 AM 10/3/2001]
Old Oct 3, 2001 | 01:23 PM
Big Phat R's Avatar
Or it could be a bad ECU connection somewhere. Are you using a V-AFC?
Old Oct 3, 2001 | 03:40 PM
2fcknfst's Avatar
Default Re: Idle control valve (Big Phat R)
I'll try the rag trick. I am skeptical because the car does return to a normal idle... so we will see.
ECU connection? No, the other TB worked fine. The irony is that the other one was a pre-production unit I was not meant to have, yet it worked better than the production unit. Holley offered me a job; due primarily to the fact that I got the pre-production unit to work and no one else could. It was kind of funny....
Anyways, thanx. I will try and report.
turbodailydan
Engine Management and Tuning
Feb 27, 2010 01:07 PM
turbodailydan
Oct 22, 2009 12:48 PM
h22vt
Apr 20, 2006 09:34 AM
