obd2a to obd1 conversion harness help!
Old Jan 23, 2004 | 04:54 PM
BringIT's Avatar
Default obd2a to obd1 conversion harness help!
I've got a 98 JRSC GSR.
I'm throwing 2 CELs after I connect my p28 ecu.
I'm pretty sure there's a problem with my conversion harness. When I plug in my stock ecu obd2a p72, I get no CEL's.
When I plug in my p28 (custom chip) I get CEL 20 and 41
When I plug in my tuner's p28 I get CEL 19 and 20
Where is the obd2a connection for the Heated Oxygen Sensor Heater? and where is this wire suppose to go on the obd1 connector??
Old Jan 23, 2004 | 04:58 PM
BringIT's Avatar
Default Re: obd2a to obd1 conversion harness help! (BringIT)
From this image, It appears that the heater sensor is D13 and D14
http://www.autoserve.8m.com/cg...2.jpg
This site shows that D14 is not used on OBD1
http://www.hondaswap.com/swap/viewer.php?id=58
But what about D13?? D13 is missing from the list!
Old Jan 23, 2004 | 05:24 PM
BringIT's Avatar
The obd2a D7 (PHO2S) is connected to C14 (P02)
The obd2a A6 (P02s) is connected to A6 (HO2D)
shouldn't
obd2a's D7 be connected to obd1 A6? and
obd2a's A6 be connected to C14
nicko360
Aug 12, 2007 07:29 PM
94eg5squadMD
May 4, 2007 10:58 AM
JDM00SI
Oct 31, 2005 01:54 PM
jdmteg01
Aug 19, 2004 09:42 PM
stehigs321
Feb 21, 2004 04:07 PM
