Cali Smog...O2 sensor Question
I'm converting my 1st gen B16 (90 hatch) from OBD0 to OBD1. I'm using the stock B16 exhaust manifold which uses 2 O2 sensors. Since I'm going OBD1, all that I need is (1) 4 wire O2 sensor...what happens to the other hole where the 2nd O2 sensor goes. I'm trying to get this smogged and trying to visually make it look as clean as possible.
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_Ro »</TD></TR><TR><TD CLASS="quote">I'm converting my 1st gen B16 (90 hatch) from OBD0 to OBD1. I'm using the stock B16 exhaust manifold which uses 2 O2 sensors. Since I'm going OBD1, all that I need is (1) 4 wire O2 sensor...what happens to the other hole where the 2nd O2 sensor goes. I'm trying to get this smogged and trying to visually make it look as clean as possible.
TIA</TD></TR></TABLE>
Simple, replace the header with an OBD-1 style.
