d16z6 swap into 88 crx si questions..
Old Jan 23, 2004 | 09:37 AM
firstgenrex's Avatar
Default d16z6 swap into 88 crx si questions..
ok will the 88 tranny work with this i know 89-91 is different, and also im thinking of getting the boomslang obd1 kit, and so whats the deal with the sensor thats on it filled by a bolt? can i leave it unhooked, ahh i g2g but ill piost my other question when im home
Old Jan 23, 2004 | 10:00 AM
Z6REX-SI's Avatar
The 88 si tranny will work just fine.
Old Jan 23, 2004 | 10:33 AM
JCracer723's Avatar
Default Re: (Z6REX-SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z6REX-SI &raquo;</TD></TR><TR><TD CLASS="quote">The 88 si tranny will work just fine.</TD></TR></TABLE>
if u use 88 crx clutch press. plate and flywheel .. i believe
Old Jan 23, 2004 | 11:55 AM
Z6REX-SI's Avatar
That's correct.
Old Jan 23, 2004 | 01:25 PM
Doctor CorteZ's Avatar
Default Re: (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">
if u use 88 crx clutch press. plate and flywheel .. i believe</TD></TR></TABLE>
use 89 up , its 30mm larger surface area.
Old Jan 24, 2004 | 03:51 PM
i have an 88 and if i wanna swap the tranny i have toswap to 89-91 axles which isnt really worht it cause i just got a brand new clutch and i already have an 88 si. ok my other questions, how do i run the sensor on the d16z6? i think its the cam angle sensor or the knock sensor, its on the back of the engine but its filled with a bolt, the 88 si has the sensor in it and i could always swap em into the d16z6 but i dont know cause ill be using the p28?? ecu from the civic ex
Old Jan 24, 2004 | 07:44 PM
shorty91's Avatar
Default Re: d16z6 swap into 88 crx si questions.. (firstgenrex)
the thermo sensor must be relocated from the back of the si block:
to the z6 thermostat because the back of the z6 block is filled in:
with obd1 you have to add the vtec wires as well
my car is obd0 with a zdyne one wire conversion
Old Jan 25, 2004 | 09:22 AM
so the green 2 prong one, that will just screw right in correct?
Old Jan 25, 2004 | 10:23 AM
slowem1si's Avatar
Default Re: (firstgenrex)
the trans will work i did a temporay d16 si swap in my rex and used the hf trans with a d16 si clutch and flywheel i had laying around.
cr-x-91
Sep 10, 2007 09:17 PM
g_rant2006
Feb 6, 2006 08:48 AM
fresnodx
Sep 8, 2004 08:31 PM
Project_ED8
Jan 16, 2004 06:01 PM
tgreaves
Dec 3, 2003 01:14 PM
