Autometer VAC install
Old Jan 23, 2004 | 08:55 AM
JDMRob's Avatar
Default Autometer VAC install
He fellas i recently received a autometer vac and I was wonderin how to install it. There are 2 wires runnin from it one is red and one is white. I am pretty sure the red one is for power but what do i do with the white one. Any help is greatly apprecatied.
Old Jan 23, 2004 | 12:50 PM
JDMRob's Avatar
Default Re: Autometer VAC install (JDMRob)
up
Old Jan 23, 2004 | 01:14 PM
JSPECHB's Avatar
Umm, dont you have the directions? The other wire I THINK should tap into your TPS.
Old Jan 23, 2004 | 01:22 PM
JDMRob's Avatar
Default Re: Autometer VAC install (JSPECHB)
nah no directions it was given to me an the person who gave it to me has no clue either Help any 1
Old Jan 23, 2004 | 01:34 PM
93civicEX's Avatar
There gotta be more than that, I mean you need to have a Power and a ground, is this mechanical or electrical gauge?
Old Jan 23, 2004 | 01:37 PM
JDMRob's Avatar
Default Re: (93civicEX)
its electrical cuz it has a light well thats all i got wit it
Old Jan 23, 2004 | 01:42 PM
Ricey McRicerton's Avatar
Default Re: (JDMRob)
Ummm..if it's a vaccum guage you should tap into your brake booster line and run your line to the back of the guage. As far as the lights go, tie the negative wire to a bolt wherever you want to put it and tap the power into the dimmer switch wire for your guage cluster.
Old Jan 23, 2004 | 02:55 PM
Del Sol SiR's Avatar
Or try Autometer directly...
Here, I'll hook you up !
http://www.autometer.com/hp/in...9.pdf
Old Jan 23, 2004 | 03:52 PM
JDMRob's Avatar
Default Re: (DelSolSiR)
thanks fellas
d15nonvtec
Jul 25, 2006 12:09 PM
tyflip2
May 26, 2004 07:13 AM
dohcMONSTER
Jan 30, 2004 06:45 PM
LS_racer
Dec 29, 2002 08:21 PM
paulyman
May 11, 2002 08:46 PM
