Idler Pulley Question
Hey guys im about to buy a del sol vtec ac bracket for my b16 swap in my 5th gen hach, so i can retain the stock d-series ac compressor. Will the idler pulley off of the d-series work with the del sol bracket? I know the rubber mount will, but i wasn't sure about that.
TIA
TIA
Use the civic compressor with a del sol DOHC VTEC (p54) a/c mount. The belt has the same amount of ribs IF it is 94+ crank pulley. Older B16s have the one rib style crank pulleys.
i was going to use del sol vtec belts for the ac and alternator, my main question was whether or not i could use the d-series idler pulley with the del sol vtec ac bracket. thanks man.
ill have to say no on this one. Seams that i had to use the one off a b series due to the d not fitting. But mine is a 97 with a b20 a/c bracket. Should work in your case and it is 1/2 the price on the p54, stamp on b20 bracket was p7j. It has been a year since the swap so i dont know if this is corect, might have used the idler pully off the b20 just cause I had it.
makibaka
13
May 10, 2004 09:13 AM
