Clunking Suspension (HELP)
Old Jan 23, 2004 | 06:13 AM
xexjh09's Avatar
Default Clunking Suspension (HELP)
I have a 95 teg. My car has been lowered, but I thought that it needs to be lower. So I l adjusted it even more with coilovers.. Then I got on to the street and my car started to pull left and it was making a clunking nosie from the axle (Left Side). Later on the next day My axle snapped. So I thought that It might have somthing to do with my struts. So I put Some Tokico gas struts in the front and a new axle in yesterday. No it doesn't pull to the left anymore, but it still makes the clunking noise. Now it does the noise to both sides. Sounds like something is hitting it. I can't figure it out. Would it be a lower control arm?? I am on my 3rd axle this week.
Any advice would be helpfull... Thanks
Old Jan 23, 2004 | 07:23 AM
Honda Hick's Avatar
Default Re: Clunking Suspension (xexjh09)
How fuggin low are you dropped???
Old Jan 23, 2004 | 07:54 AM
xexjh09's Avatar
Default Re: Clunking Suspension (Honda Hick)
A couple more turns then I will be all the way down...
Old Jan 23, 2004 | 01:22 PM
chad174's Avatar
raise it back up and see if it does it. probably something with your radius rods, control arms, or the forks of your struts.
Old Jan 23, 2004 | 05:05 PM
Sliced Beard's Avatar
Default Re: Clunking Suspension (chad174)
dude you are too low
you will kink the axles if you slam it too much
i just lowered my hatch and i dont like all of the noises that are coming from my car i will be raising my car back up and i suggest you do the same
Old Jan 23, 2004 | 08:48 PM
EG-lowrider's Avatar
did you get the upper pillow mount bushings torqued down enough, I had an expierence with mine after on the car for about 2 yrs. and last week I noticed all the strut tops and washers were very loose. it makes the springs and struts dance around on the mounts. hope this helps.
gotgohan
Sep 22, 2013 08:33 AM
ej1jdmtyper
Transmission & Drivetrain
Oct 22, 2012 07:33 PM
royalrebel
Oct 6, 2009 03:04 PM
TomFin
Feb 20, 2006 11:08 AM
xexjh09
Jan 23, 2004 01:12 PM
