Need body work help.....
Old Jan 22, 2004 | 10:34 PM
Infinite Auto's Avatar
Default Need body work help.....
ok i bought an ef hatch the other day that it has rusted rear quarter panels, i also have this hatch in my garage......i want to fix the hatch i bought because it will be my daily driver (20 days until i get my license back)......i plan on cutting out the quarter panels on this and putting them on my daily driver, the rust on my new one is somewhat near the blue in the picture, and would the red lines be a good place to cut??? then weld it to the other car and do a bit-o-bondo.....or any other ideas.....thanks!
Old Jan 22, 2004 | 10:44 PM
hybridzOr's Avatar
Default Re: Need body work help..... (B18TurboEF)
is that the hatch you bought from carlos? do you have pics of his hatch?
sorry to be off topic
Old Jan 22, 2004 | 11:04 PM
Default Re: Need body work help..... (Hybrid Racer)
nope and nope......ill get some pics of it whenever i get a chance.....its gonna be going through a lot soon.....
Old Jan 23, 2004 | 04:22 AM
Fobtions's Avatar
for that much damage it wouldnt be worth cuttin where u have marked. theres plenty of different restoration techniques that can be done.
Old Jan 23, 2004 | 04:28 AM
ebelp's Avatar
Default Re: Need body work help..... (Fobtions)
You should talk to this guy.
https://honda-tech.com/zerothread?id=724309
Old Jan 23, 2004 | 04:37 AM
The_Todd's Avatar
Farts in the shower
Default Re: Need body work help..... (ebelp)
http://www.cb7tuner.com/vbb/sh...=2868
Here is another good link, its for accords but quarter panels and rust are the same. Good luck.
Old Jan 23, 2004 | 12:01 PM
Default Re: Need body work help..... (VRDrvr)
ok cool, anybody else have some info? i was thinking about replacing the whole thing now that i saw the link of the eg hatch......
Old Jan 24, 2004 | 08:03 AM
eL_cArLos's Avatar
Hey thats my old car!!!
Old Jan 24, 2004 | 11:38 AM
Default Re: (EF9*****)
no thats my car thats been in the garage............and i dont have your car anymore
Old Jan 24, 2004 | 06:21 PM
LoSt is BlaCk's Avatar
Default Re: (B18TurboEF)
that looks like not a lot of rust but a lot of work! i think a good body shop can cut out the rust and rework the metal, before cutting that much of the car is cut out, if you use that car to fix the new one, what are you going to do with the one you have a pic of up top?
Old Jan 25, 2004 | 08:21 PM
eL_cArLos's Avatar
what did you do with my old car?
Old Jan 25, 2004 | 10:11 PM
stizzit's Avatar
You're in luck because i just finished doing a rust repair on my teg in the same place as your upper rust spot. However If you plan on doing this yourself make sure you have all the right supplies especially body hammers, an oxy/acelene tourch, and obiously a mig welder.
I would NOT cut out what you said, I would isolate each rust area and add a few inches to account for unseen rust, or just wirebrust the rust/paint back to see how far it streches. NOTE: On mine it was much worse on the inside (rusted inside out) so be careful to remove it all!! If you cut where you said, first of all that fender line will be a Bi*ch to work with body filler. Second, honda probably has the thinnest sheetmetal EVER so you WILL warp it (hence the torch to shrink it and the body hammers to shape it) no matter how hard you try. Cutting a section out as large as you want to will leave your entire rear quarter filled with 5lb's of body filler.
You want to have a happy compromise between removing just enough metal to get all the rust, and removing too much where you'll ruin the panel.
You do realize you can't "Weld" the panel back in but you must "spot weld" it in? This took me a very long time, about a full 2 days for both the outer panel AND the inner fender well. If you just plan on welding one bead, you might as well quit now because your panel will look like a tortilla.
You could always remove the factor seam sealer, drill the spot welds, and remove the entire quarter panel . Good luck with whatever you do but I can GUARANTEE you its 10x more work than you think and will take you 10x longer than you think IF you plan on doing any hint of a good job. Do some reading before you start this project or you won't be happy with the outcome.
BTW: Square patch panels warp easier than round ones.
Old Jan 25, 2004 | 10:13 PM
UPS's Avatar
UPS
Looks like a lot a work and some long cuts. Might want to do it like the blue hatch it will be more work but less visible of the smaller cuts. Most of the cuts are at spot welds. Most of the work is in the jams.
slo_hatch
Nov 6, 2008 05:09 PM
HONDA_CIVIC_HATCH_Boy
Feb 3, 2006 08:15 PM
RoaringTurtle
Jul 9, 2003 11:23 PM
Awax223
Jul 12, 2002 05:20 AM
