crx sir cluster anything else needed?
Old Jan 22, 2004 | 09:58 PM
bardo's Avatar
Default crx sir cluster anything else needed?
im about to put the crx sir cluster in my 91 hf...b/c im doing a swap and need something that revs out past 8....ive put an sir cluster in my eg before and didnt need any extra wiring or pieces...anybody know if i need anything extra besides the cluster for the crx sir 1?
Old Jan 22, 2004 | 10:44 PM
sir91's Avatar
Default Re: crx sir cluster anything else needed? (bardo)
Your going to need an electronic speed sensor
Old Jan 22, 2004 | 10:53 PM
Nerologic's Avatar
ypu u need a VSS for either tranny you are going to use the cluster with...or are d series and b series VSS the same??
Old Jan 23, 2004 | 05:38 AM
civicsir.com's Avatar
this is something worth looking at:
http://b16a.honda-perf.org/cluster.html
Old Jan 23, 2004 | 07:51 AM
bardo's Avatar
im using a b16 tranny...thanks for the site too...
Old Jan 23, 2004 | 08:27 AM
crxtreme89h's Avatar
You don't need a new cluster to rev to 8K with the new swap. Your ECU is what controls your REV limit, not your cluster.
I see what you mean though. The SIR cluster would be nice. Do you know how to rewire?
Old Jan 23, 2004 | 11:28 AM
90civichbsi's Avatar
Default Re: crx sir cluster anything else needed? (crxtreme89h)
I used my old d16a6 speed sensor for my bseries tranny when i swaped to a b16 just like everybody does that uses the stock cluster.
so all D&B series should be the same. but i have never tried.
Old Jan 23, 2004 | 06:01 PM
bardo's Avatar
ya ok but my car car can shift out until 8,5-9...so i obviously need a rpm gauge that reads past 8...the stock HF 1..stops at exactly 8...so how would i shift at 8,5 if it doesnt read any further..i obviously need a new cluster that reads past 8.thats my point
Old Jan 23, 2004 | 06:15 PM
brent_G's Avatar
did you get the plugs with it?
Old Jan 24, 2004 | 12:04 AM
bardo's Avatar
i didnt get the cluster yet im ordering it from a friend shortly
Old Jan 24, 2004 | 02:31 AM
sircrxracer's Avatar
Default Re: crx sir cluster anything else needed? (brent_G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">did you get the plugs with it? </TD></TR></TABLE>
Do you need the plugs with it???? Rob
Old Jan 24, 2004 | 07:07 AM
brent_G's Avatar
Default Re: crx sir cluster anything else needed? (sircrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">
Do you need the plugs with it???? Rob</TD></TR></TABLE>
yup. ur stockers dont fit in the new cluster.
Old Jan 25, 2004 | 03:32 PM
bardo's Avatar
so whats everything i need in order to put the cluster in...im using a LS cable tranny too...i need the cluster...plugs...vss? is this right or what
Old Jan 25, 2004 | 04:13 PM
brent_G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bardo &raquo;</TD></TR><TR><TD CLASS="quote">so whats everything i need in order to put the cluster in...im using a LS cable tranny too...i need the cluster...plugs...vss? is this right or what</TD></TR></TABLE>
Yeah those three things. Just as long as the vss is a electronic one.
Old Jan 25, 2004 | 04:32 PM
bardo's Avatar
where can i get the VSS from?
Old Jan 25, 2004 | 06:50 PM
brent_G's Avatar
umm pretty much any hydro tranny
Old Jan 25, 2004 | 06:52 PM
bardo's Avatar
so just take the VSS out any hydro tranny n i can use it on my cable?
Old Jan 25, 2004 | 08:07 PM
brent_G's Avatar
Yeah..you need the clip that goes on the sensor also. then you splice the 3 wires...one goes to power, one goes to ground, the other goes to the cluster.
blasterman87
May 9, 2010 07:47 AM
MrJDM_
Feb 13, 2010 07:58 PM
LB CRX
14
Aug 31, 2002 08:34 PM
