toyo proxes on 14 hx wheels
Old Jan 22, 2004 | 08:50 PM
CRXracer88's Avatar
Default toyo proxes on 14 hx wheels
wut do you guys think will the 195/45/14 be to low of profile does anyone one have these tires in 14s either of the 2 sizes they make 195/45/14 or 195/55/14 if so let me no if you like them. any pics of them on 14 in rims would be nice to ..later
Old Jan 26, 2004 | 05:37 AM
CRXracer88's Avatar
Default Re: toyo proxes on 14 hx wheels (CRXracer88)
has anyone used these tires in 14s?
Old Jan 26, 2004 | 07:06 AM
dr_latino999's Avatar
How much of a drop is going with these tires?
Old Jan 26, 2004 | 08:40 AM
feelsfast's Avatar
Where can you find tires in that size and profile.
Old Jan 26, 2004 | 11:47 AM
CRXracer88's Avatar
Default Re: (feelsfast)
prolly just a 2 in all the way around ... and i found them at a local dealer here in ohio they said that they have 8 195/45/14 left and 12 195/55/14... there like $78 a tire though.
Old Jan 26, 2004 | 12:05 PM
86ludeSi's Avatar
Is your stock size 185/60 14? if so, and the 195/45 will be alot smaller, go to http://www.miata.net/garage/tirecalc.html it's a tire size calculator, it's really useful
Old Jan 26, 2004 | 12:27 PM
Kasper.'s Avatar
Default Re: (86ludeSi)
I worked at a tire shop many a years ago, when sold those exact tires, Good overall tires, but from what I a can tell you may have sealing problems around the bead, but I know for a fact guys on here are running 195 azenis on there 14 incheer's and are having no problems.
Old Jan 26, 2004 | 01:47 PM
CRXracer88's Avatar
cool thanxs so the 195/45/14 will be way to small acorrding to that site ill prolly just go with 195/55/14 ... these should be alittle bigger width than the stock 185/ right?
Old Jan 26, 2004 | 06:58 PM
Kasper.'s Avatar
Default Re: (CRXracer88)
yeah 10mm or maybe its centimeters ah hell I cant remember.
Old Jan 26, 2004 | 08:37 PM
hatchlessrex's Avatar
i found only 55s in that size but then again i could been goin through a bad source. nut the 55 are what i am running now on my rex.
Old Jan 27, 2004 | 01:13 AM
davens's Avatar
I'm running 195-60-14 Azenis on a 14x6 right now. No problems.
I was running 195-60-14 Azenis on a stock CRX rim(14x5.5). No problems.
I have also run 195-55-14 Bridgestone RE-71s on a 14x5.5. No problems.
I believe the HX rim is a 14x6. Tirerack says the 195 width is good for a 5.5-7" range.
The 195 in 195-55-14 is millimeter width. See:
http://www.tirerack.com/tires/...e.htm
TypeOneSiR
Aug 1, 2008 12:30 PM
924doorEG
Dec 21, 2007 07:12 PM
b16_madman
Jun 30, 2005 11:26 AM
Thirty-Nine
11
Feb 3, 2004 07:24 PM
WangChung
12
Jul 24, 2003 11:26 AM
