h22a gonna be boosted ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjirex »</TD></TR><TR><TD CLASS="quote">Hey guys,
I really wanna boost to 10psi on my h22. its a 92-95, so its got a closed deck (whatever that means?). now i know its not a good idea by any means to boost a stock h22 to 10 psi, so what would i need to SAFELY run this?
i need to drive around 50 miles/day, 7 days/week so i cannot have to be worrying about the engine being hurt. i mean, i could go to like 8 psi, but the goal here is to be boosted on a budget with some good torque. i already am looking at a t3 of some sort. i dont like the idea of high revving to get the most out of a turbo (ie. t5 or even t4) at all.
but i was thinking if i just got the engine sleeved and new cam shafts, would that be sufficient or what should i get to safely boost to 10psi or so???
could i simply buy a boost controller and use 7psi on daily driving and 10psi for weekend racing?</TD></TR></TABLE>
If you want the safest type of set-up and have the money here is what I recommend:
basic turbo kit
t04e .50 comp trim .58a/r t3 trim turbo (great for street)
walbro intank 255 fuel pump
Hondata s200b
Boost Controller - Apexi AVC-R is what I recommend
With those things I would boost 8psi daily and 10psi at the track given the motor is tuned with higher octane fuel on 10psi. The problem with boosting the H series are the weak ringlands, but they put down great hp #'s. Personally I would not go above 9psi with a stock motor but that's just me...
Do a compression and cylinder leakdown test before you go turbo to make sure your internals are holding up well before you add the increased stress to them.
basic turbo kit
Hondata s200b
pcguy760
Jun 14, 2006 06:49 AM
