About To Run System For First Time, do I have everything right?
Old Jan 22, 2004 | 05:17 PM
Full Race A6's Avatar
Default About To Run System For First Time, do I have everything right?
Have my system pretty much done and have gone over everything twice. BUT I really dont know about inverting my subs and how they are supposed to be wired. Heres a pic of exactly how I have it installed:
Now I forgot about the rcaa's in the pic but they are there.
Now the way I did the remote wire is cool right? By splicing into the one that goes directly into the headunit?
I wired the amps up to what I was hoping was 20hm. The subs are Audiobahn AW1206T's 12's.
I wanna start this system out tomorrow but wanna make sure I have not royally missed something and will blow right away.
I guess you can see everything I can think of in the pic. Cant think of anything else. Power and ground is 4gauge. In a huge (forgot specs) ported dual chamber box
Ill answer any questions you guys have.
Old Jan 22, 2004 | 06:05 PM
GAtegs's Avatar
Default Re: About To Run System For First Time, do I have everything right? (PIMPIN)
I would recommend running power like you did with the remote, you know, splitting it up when you got to the amps not running 2 separate cables, but I guess if you've done it already...Everything else looks good.
Old Jan 22, 2004 | 06:07 PM
GAtegs's Avatar
Default Re: About To Run System For First Time, do I have everything right? (a98tegLS)
And if the sub on the left is inverted too, you are gonna wanna swith the polarity of that 1 too, unless you just didnt draw it properly.
Old Jan 22, 2004 | 06:21 PM
oh chit. I made the picture wrong. Both subs are going from + 2 + and - 2 -
should I switch them around on the amps? Does it matter?
I never really thought about it.
Old Jan 23, 2004 | 04:19 AM
Old Jan 23, 2004 | 06:57 AM
Hondaaccordvtec's Avatar
The way you have your original pic - your set-up will be fine.
Old Jan 23, 2004 | 08:44 PM
Default Re: About To Run System For First Time, do I have everything right? (Hondaaccordvtec)
Info on reversing the polarities?
Old Jan 23, 2004 | 10:14 PM
GAtegs's Avatar
If the subs are inverted, and you have a regular sealed (or I guess ported box) then the polarity should be switched.
Old Jan 23, 2004 | 10:25 PM
vigor5spd's Avatar
What kind of headunit do you have? Does it have a sub preout? If so check and see if you can change the phase on the sub output.
guru350
Audio / Security / Video
Jan 8, 2013 11:47 AM
mozzandherb
Jul 2, 2007 08:55 AM
phateless
May 10, 2006 11:19 AM
Gmedalion
Apr 24, 2003 06:02 PM
performula
Feb 22, 2003 06:18 PM
