AHHHHHHHH!!!!!!!!!! I need help ASAP!!!!
Old Jan 22, 2004 | 05:00 PM
speed_racer012's Avatar
Default AHHHHHHHH!!!!!!!!!! I need help ASAP!!!!
Just drove down the road and my entire car just died all at once. the lights the interior lights the radio EVERY thing!!!!! I have a tow truck comeing to pick it up But have NO Idea what it is. I had tools on the passenger side floor where the Ecu is and was wondering if it got unplugged some how. Help ASAP!!!!!
Old Jan 22, 2004 | 05:03 PM
ThatRicerDaniel's Avatar
Default Re: AHHHHHHHH!!!!!!!!!! I need help ASAP!!!! (speed_racer012)
maybe you should go look .. I would think the ecu is a good place to start. if its all good check your voltages from battery.
Old Jan 22, 2004 | 05:07 PM
Default Re: AHHHHHHHH!!!!!!!!!! I need help ASAP!!!! (NitrousDreamz)
Heading out there right now it didn't even give me any warnings just shut off!
Old Jan 22, 2004 | 05:47 PM
Well my ECU was hooked up but SOMTHING is defenitely loose, as I was towing it home when I hit the pothole at the end of my street everything came on at once then by the time i got home and lowered the car back to the earth it stoped working again. I'm throwing a code 20 and a code 12. don't know what those mean but I'm in the process of searching. I know somebody did a whole list of them all on here somewhere.
Old Jan 22, 2004 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4g vtec &raquo;</TD></TR><TR><TD CLASS="quote">thanxs... hope it comes up when somebody does a search... the simple title should work</TD></TR></TABLE>
Well it did and I have a electric load? code 20 what is that?12=exhaust gas recirculation system(exhaust?)
Old Jan 22, 2004 | 05:55 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Make sure that your Negative battery cable is tight, and the terminals are all clean... happened to me once. Also, check the underhood relays, and the big connector that's covered in that amber rubber.
Old Jan 22, 2004 | 05:57 PM
Default Re: (VashTheStampede)
Thats what I'm thinkin of doin next. I checked the terminals and they were both fine.
Old Jan 22, 2004 | 06:08 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">Make sure that your Negative battery cable is tight, and the terminals are all clean... happened to me once. Also, check the underhood relays, and the big connector that's covered in that amber rubber.</TD></TR></TABLE>
Exactly what happend to me...i was working on my car and disconnected the battery. When I went to put it back together i must of not tightend it enough cause it popped off but kept running until i let off the gas then it just died when I stopped at a light.
Old Jan 22, 2004 | 06:09 PM
Smokinsax's Avatar
The Boot
check your ground from the battery...
Old Jan 22, 2004 | 06:13 PM
Default Re: (Smokinsax)
yeah I will check that too but when i had a bad ground before I could tell that it was dying/going to die. this time Everything was running perfect(use that term lightly) then just shut off just like that It scared me kindof at first cus it is pitch black on that street and it just went dark, then drove for a little bit and pulled off on the side of the road
Old Jan 22, 2004 | 06:27 PM
Looks like I'm throwing a code 1 too oxygen whatever.
Old Jan 24, 2004 | 01:19 PM
Well I was looking at all my wiring and the ground wire from the -battery terminal to the frame looked like it melted a little up close to the terminal. Would a short like that caused my car to spontainiosly(sp) shut off all at once? and could it have messed up my battery/starter/alternator?
civic efb16
Oct 16, 2005 11:57 PM
civicEXtreme
Oct 6, 2005 11:32 AM
grvn1
Audio / Security / Video
Feb 2, 2005 08:52 PM
hatchinprogress
Jan 13, 2005 08:39 AM
