compression test procedure info needed
Old Jan 22, 2004 | 03:25 PM
gregv's Avatar
Default compression test procedure info needed
want to perform a compression test on my DOHC ZC in my '91 Civic,
as it is currently running on three cylinders. From what I understand,
I have to disable the fuel pump and possibly open the throttle body
butterfly all the way. Is this correct? If so, is the best way to disable
the fuel pump by removing a fuse? And does the butterfly have to be
opened fully?
any info appreciated
greg v
Old Feb 15, 2004 | 12:04 AM
Combo's Avatar
Default Re: compression test procedure info needed (gregv)
Check out this page
http://www.c-speedracing.com/h...t.php
Si_chRis
15
May 26, 2006 08:46 AM
4thgenner
Feb 21, 2006 07:51 AM
SexyH22
May 1, 2005 10:45 AM
1FastCoupe
Apr 13, 2005 09:31 PM
gregv
Jan 22, 2004 06:19 PM
