Best single cam non vtec head?
Just looking for some ideas of what you guys think is the best non vtec head? Im debating between the a6, y7 and b7. I can use the B7 off of my car now for my d16z6 bottom end but I was wondering what timing belt I'd use. Thanks for your help,
Matt
Matt
From: the asshole of america..., upstate new york, USA
if im not mistaken the a6, b2, and b7 are the same casting...just different cams and valvetrain. i know the a6 and b2 are the same and i <u>think</u> the b7 is too. the y7 has a smaller combustion chamber...same size as z6 (so i would assume they are similar castings...but again i am just guessing on that) and also 1mm bigger valves. not that that will help much on the 75mm bore size.
ive always read as a general rule of thumb to use the timing belt for the head your gonna use. ie...a6 block z6 head = z6 timing belt. but ive never tried it so better get more feedback first.
as for which ones the best???
if you want best stock setup go with the A6 head but if you are rebuilding it then it doesnt matter B7 and A6 are identical with the new generations have the Z6 casting but without Vtec and a smaller combustion chamber depends on whether you want more compression or not.
SOHC_MShue
15
Jun 3, 2005 06:18 PM
