rear discs w/o new trailing arms?
i've read through the how-to's, but i didn't see whether it was possible OR how-to install Si rear discs on an ek hatch WITHOUT using the complete trailing arm from the Si.
i heard it was possible to just switch out the drums and replace with discs, but i don't know how to. i have the complete trailing arm assembly from an Si, but i think the trailing arm might be bent. i installed them about a month ago but i had TOE in and positive camber (originally had negative camber). i know for a fact that my trailing arms aren't bent, so i thought i'd use those.
will it be too hard? also, how do you replace the hub bearings?
i'm still a noob
i'm still a noob
FlewByU352
11
Aug 18, 2013 09:47 AM
Mr_CRX
32
Dec 17, 2004 08:29 AM
