Rebuilding engine, Bearing question
Old Jan 22, 2004 | 01:53 PM
tgreaves's Avatar
Default Rebuilding engine, Bearing question
I am rebuilding a d15b2 and im confused on the bearings.. I know there are different color bearings for different thicknesses.. Do I buy a set of bearings, install them, and then check the clearances with plastigauge, and then if they are too tight or to small go get a new bearing for that main or rod?? Also toga only sells 1 size bearing for the hondas.. Do I need to get the bearing shaved or something to fit within spec??
Old Jan 22, 2004 | 05:52 PM
jdmhatch94's Avatar
Default Re: Rebuilding engine, Bearing question (tgreaves)
yeah u would have go through some bearings to find the right ones if the one size all ones dont fit correctly... jsut use the codes from the block and if to thick/thin use the size chart in the manual and pick accoridinly it will help some... jsut plasitguage the heck out of it!!!!!
VTEC-ALL-DAY!
Dec 17, 2013 04:43 PM
neonkid
Oct 24, 2012 01:57 PM
aznwash3wboi
Oct 3, 2005 09:57 PM
bunnyrabbit
Mar 29, 2004 05:20 AM
sir2k
Mar 5, 2003 11:33 PM
