what mounts do i need for b20 in eg?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupe_hybrid »</TD></TR><TR><TD CLASS="quote">Any b-series mount would work.</TD></TR></TABLE>
Really? Go try the swap using 99 Si engine mounts. ALL of them. Then tell me any B series mount will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Really? Go try the swap using 99 Si engine mounts. ALL of them. Then tell me any B series mount will work.</TD></TR></TABLE>
I was thinking the same thing
Laff...i was just about to comment on that one!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin »</TD></TR><TR><TD CLASS="quote">which mounts is it??? hasport b-series mounts for a eg work??</TD></TR></TABLE>
You could use 94-up integra mounts including the rear bracket and it should bolt in for alittle cheaper than hasport.
if you get hasports mount kit, you're still going to need the rear bracket off of the b series motor from any 94-up integra. No the 99-00 B series aint going to work.
Whole complete stock OEM gsr mounts and brackets may run about 100-200 depending who/where u buy them from
Hasport around 300-600 depending who you buy them from
Hayame as if you didnt know also came out w/ mount kits for b series swap in EG's. Looks just like hasport mount but i heard they perfected it a but more for liability. will run around 400.
Hope this helps.
Hope this helps.
You also need the bracket that mounts to the engine itself from a teg. I'm just finding this out myself as I try to mount the LH mount and it has nowhere to go.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin »</TD></TR><TR><TD CLASS="quote">So there is 96 teg in a near by junk yard which holds a LS,I could use those mounts correct?</TD></TR></TABLE>
yes
yes
Thanks VTECVillain - that pic was really helpful - but this means I still need two more brackets for my swap...grr
Does anyone know if the CRV AC bracket work instead of the teg brkt??
the bracket thats on the block with is the driver side mount will more than likely have to be changed to fit the integra mount the mount it comes with is angled 2 bolt and integra is straight 3 that is the only mount problem i encountered
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swaytec360 »</TD></TR><TR><TD CLASS="quote">the bracket thats on the block with is the driver side mount will more than likely have to be changed to fit the integra mount the mount it comes with is angled 2 bolt and integra is straight 3 that is the only mount problem i encountered </TD></TR></TABLE>
I figured that out, but I need to know if the lower lh ac bracket mount from a crv might work? I wont be using ac, just need to know if it'll be in the right place....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PartsChic »</TD></TR><TR><TD CLASS="quote">
Yes it will work, and you can keep yor civic A/c compressor with that mount too if you wanted.
Vtecvillian beat me to the pic of the mounts (Katmans)
</TD></TR></TABLE>Yes it will work, and you can keep yor civic A/c compressor with that mount too if you wanted.
Pompiuses
Oct 18, 2007 11:50 AM
conceptEG
Nov 8, 2006 05:03 PM
battlecrxT
Jan 12, 2006 04:12 PM
I live in Buffalo ny - no need for ac here lol!
