which ecu should i use for my b16 swap????
Old Jan 22, 2004 | 12:27 PM
ironchef25's Avatar
Default which ecu should i use for my b16 swap????
hello guys. im about to pick up my motor in hmotorsoline to get my crx swap for the weekend. and i dont know what ecu to get, the pr3 or the pw0. now whats the diffence between the two. and does it matter? which one is better??
Old Jan 22, 2004 | 12:28 PM
EL Vap133's Avatar
Default Re: which ecu should i use for my b16 swap???? (ironchef25)
I don't think there is much difference, I am using the PWO and it's cool. When are you getting your car done?
Old Jan 22, 2004 | 12:58 PM
ScottEK's Avatar
Default Re: which ecu should i use for my b16 swap???? (EL Vap133)
I know there is a difference, but I can't remember what it is, the PR3 is the one to get.
Old Jan 22, 2004 | 01:15 PM
ironchef25's Avatar
Default Re: which ecu should i use for my b16 swap???? (beta13)
then whats obd0 and obd1 its one is obd1 and the other is obd0???? i thought depending on your ecu. thats what determine the obd0/obd1 thingy. sorry if im being an idiot. i dont know any thing about these stuff. im more like a computer nerd.dont know anything about these heheehehe. and which obd is better.
Old Jan 22, 2004 | 01:48 PM
rice_classic's Avatar
if it's obd0 and it's just a daily driver the PR3 is great. The pw0 is just a waste of time, stock that is.
I have a pr3 for daily driving and a "chipped" PW0 for trackdays and the such.
If I had OBD1 (in hindsight I should have gotten in the first place!!!!) I would use something like a p72 and a vafc
Old Jan 22, 2004 | 02:38 PM
temp's Avatar
Default Re: which ecu should i use for my b16 swap???? (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">if it's obd0 and it's just a daily driver the PR3 is great. The pw0 is just a waste of time, stock that is.
If I had OBD1 (in hindsight I should have gotten in the first place!!!!) I would use something like a p72 and a vafc</TD></TR></TABLE>
if i had OBD-1 i would run a p30
EDIT: which i am actually going to have soon
Old Jan 22, 2004 | 02:42 PM
ironchef25's Avatar
Default Re: which ecu should i use for my b16 swap???? (temp)
so how can i distinguished obd1 from obd0???
Old Jan 22, 2004 | 02:45 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">so how can i distinguished obd1 from obd0???
the plugs will be gray on the ECU for OBD-1
Old Jan 22, 2004 | 02:46 PM
ironchef25's Avatar
so which one would be beter then obd1 or obd0?? and does is it make a difference??
Old Jan 22, 2004 | 02:53 PM
SC0TT's Avatar
PR3 has more programs available when chipping.
Old Jan 22, 2004 | 02:57 PM
Patch's Avatar
Default Re: (SC0TT)
P30 has datalogging, launch control, and more programs than a PR3 (although the PR3 does have a lot).
Looking back, I would have converted to OBD-1 also.
Old Jan 22, 2004 | 03:09 PM
MADEINIRAQ's Avatar
Default Re: (SC0TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC0TT &raquo;</TD></TR><TR><TD CLASS="quote">PR3 has more programs available when chipping.</TD></TR></TABLE>
exactly
obd1 pr3's seem kinda rare.. and deff not a desireable ecu IMO
Old Jan 22, 2004 | 03:11 PM
MADEINIRAQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">then whats obd0 and obd1 its one is obd1 and the other is obd0???? i thought depending on your ecu. thats what determine the obd0/obd1 thingy. sorry if im being an idiot. i dont know any thing about these stuff. im more like a computer nerd.dont know anything about these heheehehe. and which obd is better. </TD></TR></TABLE>
the obd0, 1, 2 depends on year of car, etc
unless you convert to obd1(you need - distributor, conversion harness, 4wire o2 sensor) then you are stuck with obd0ecus.
Old Jan 22, 2004 | 03:29 PM
EL Vap133's Avatar
Default Re: which ecu should i use for my b16 swap???? (madeiniraq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly!! Well said!
Old Jan 22, 2004 | 06:12 PM
Rywire's Avatar
I ran the pr3, then the pwo. I liked the pwo more because it fit in the mounting location better. The car ran the same for me with both units. Ryan
Old Jan 23, 2004 | 05:48 AM
ironchef25's Avatar
well i have a 88 crx hf. so i gues thats obd0 then huh
Old Jan 23, 2004 | 06:16 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">well i have a 88 crx hf. so i gues thats obd0 then huh </TD></TR></TABLE>
yes but that does not mean you cannot convert to OBD-1
Old Jan 23, 2004 | 06:38 AM
ironchef25's Avatar
so what do i gain when converting it from obd0 to obd1????
Old Jan 23, 2004 | 06:39 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">so what do i gain when converting it from obd0 to obd1???? </TD></TR></TABLE>
a newer computer system on the car
Old Jan 23, 2004 | 06:42 AM
ironchef25's Avatar
what about performance. and ive read somewhere that having obd1 helps your car pass smog and smog legal or something in that matter. im not realy sure.
Old Jan 23, 2004 | 07:44 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">what about performance. and ive read somewhere that having obd1 helps your car pass smog and smog legal or something in that matter. im not realy sure. </TD></TR></TABLE>
if you want to be smog legal in cali you MUST do an OBD-1 conversion
Old Jan 23, 2004 | 08:06 AM
EL Vap133's Avatar
Yeah, if you want to be smog legal you have to be OBD1 or OBD2, but those motors cost more $$$$....
Old Jan 23, 2004 | 08:50 AM
cursED's Avatar
I do believe the injectors are of a different type, and need to be changed as well when converting from OBD0 to OBD1, etc.
Old Jan 23, 2004 | 10:33 AM
Rywire's Avatar
Default Re: which ecu should i use for my b16 swap???? (milk)
To convert, you need: obd1= injectors, dizzy, conversion harness, 02 sensor (4 wire), and ecu. (I think thats it)
To be cali smog leagl, you need all mentioned, and a del sol, or similar intake mani. Basically it has to have the same format as the del sol, that way the ref can check proper vac. lnes, exc... Also a US ecu (obd1) is needed, they are hard to come by.
Old Jan 23, 2004 | 11:13 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milk &raquo;</TD></TR><TR><TD CLASS="quote">I do believe the injectors are of a different type, and need to be changed as well when converting from OBD0 to OBD1, etc.</TD></TR></TABLE>
Yes the injectors AND their plugs ARE different, but you don't NEED to use the OBD1 injectors and plugs to convert to OBD1. You can keep your OBD0 injectors.
If you keep the resistor box wired in and leave OBD0 the plugs.
