brake bleeding questions?
Old Jan 22, 2004 | 10:54 AM
tegrunner's Avatar
Default brake bleeding questions?
do i need to keep the master cylinder resevore closed while bleeding each wheel?
is there anything things i should know about this that is tricky
i had my girl friend pump the brakes three times and then i loosened the bleed screw and looked for bubbles i put a 1/4 inch clear rubber tube over the bleed screw and then ran that screw into a cup of brake fluid.
and then closed the bleeder screw then told my girl to let off the brake after the bleeder was closed
but the pedal is still the same.
what did i do wrong?
i put a new cylinder on the rear drums because i broke a bleed screw off
and i put a front caliper on because of the same reason
when replacing these parts could there just be alot of air in the system.
so i just need to keep on bleeding all fours untill it gets better.
Old Jan 22, 2004 | 11:01 AM
Jasper_db1's Avatar
Default Re: brake bleeding questions? (tegrunner)
No, you don't need to close the MC reservoir. You just need to keep it filled.
Did you bleed in any particular order?
You should bleed all four corners until the fluid comes out clear and bubble free. The technique sounds right. Make sure your helper isn't letting the pedal up before you close the valve.
Old Jan 22, 2004 | 11:58 AM
JimBlake's Avatar
Default Re: brake bleeding questions? (Jasper_db1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">... Make sure your helper isn't letting the pedal up before you close the valve.</TD></TR></TABLE>Better yet, try to close the valve before she gets the pedal all the way to the floor.
The original post just sounds like you quit too soon. Gotta keep bleeding until you get no more bubbles. Maybe 1/2 pint at each corner? Sometimes the rears take even more because of the long tubing.
Old Jan 22, 2004 | 02:07 PM
TRH's Avatar
TRH
Maybe this is a dumb question (and I have lots more of them)- Did the pedal go all the way to the floor when you opened the bleeder?
Otherwise - do what the others say.
Old Jan 22, 2004 | 06:38 PM
stumpyf4's Avatar
Default Re: brake bleeding questions? (TRH)
Pedal will drop to the floor. Hold it there until the bleeder screw is closed.
Pro-tip: Bleed your clutch while you're at it. Clutch pedal will go to the floor and will remain there. Pull it back up with your hand.
lxdriver
Dec 17, 2011 10:23 PM
dng
Jul 3, 2005 09:24 PM
jdmsteve2004
May 31, 2004 12:20 AM
tegrunner
Jan 22, 2004 02:23 PM
Jordan_4WS
Jan 20, 2003 02:10 PM
