can i remove my sway bars after installin z10 radius arms?
dont know why you would want to... weight maybe ? are you drag-crazy?
I think you can, I thought the sways went kind of behind the motor, while the Z10 kit was in front..... right?!?!
Sway bars total about 20 pounds in weight, removal of them will make your handling worse but it may improve your straight line traction as it then truly allows your front end to be independant. Try removing just your front, it will help your turn in.
drift2004
Aug 2, 2008 12:25 AM
