94 Accord Tein HA Kit Suspension Problems
Old Jan 21, 2004 | 11:41 PM
IntegR97's Avatar
Default 94 Accord Tein HA Kit Suspension Problems
I have a Tein HA kit on my 94 Accord. I've been having the worst ride ever. If I ran the car without any bumpstops could this be a big problem? Should I cut these bumptops to a specific mm if used @ all?
I've also opted to buy the another set of springs from TEIN, @ the spring-rate of their CS kit. Still no luck. Any thoughts or comments welcome.
Old Jan 22, 2004 | 12:03 AM
spankey167's Avatar
Default Re: 94 Accord Tein HA Kit Suspension Problems (IntegR97)
Hmm... Tein full coilover suspension should already come with bumpstops. Well for my Tein SS they came with bumpstops. But rather than the typical black ones on stock cars... they are upgraded to the harder white plastic bumpstop/bushings.
Old Jan 22, 2004 | 09:45 AM
IntegR97's Avatar
Default Re: 94 Accord Tein HA Kit Suspension Problems (spankey167)
If they werent installed could this be the big problem I have with the uncomfortable driving?
Old Jan 22, 2004 | 07:13 PM
Nick H's Avatar
New User
how low do you have them set and what setting are the shocks on?
Old Jan 23, 2004 | 07:50 PM
IntegR97's Avatar
Default Re: 94 Accord Tein HA Kit Suspension Problems (Nick H)
I'm not sure on the mm how low my drop is, but pretty much equivelant to a 2-1/4" drop. I've tried the setting all the way down, but moved them up to setting #5 on all 4 ends.
Old Jan 23, 2004 | 08:42 PM
spankey167's Avatar
Tein HA are pretty high up on the Tein suspension scale. I think you prob have a stiff *** spring rate which is causing you to have a crappy *** ride... Have you tried adjusting damper rates? I never knew they made Tein HA for the cd or even the cbs which would be the same suspension... Unless you got them from japan?
Old Jan 25, 2004 | 07:26 AM
BuddyC's Avatar
i have the tein ha for my 5th gen and it rides fine.....dont see why your having a problem. could be how you have your bumpstops. i dont recall how i did mine cuz i installed them sometime ago.....
menmydc5
18
Sep 2, 2007 09:19 AM
integra racr04
Apr 18, 2006 05:18 AM
lilCivic
21
May 29, 2005 01:03 AM
FREAKquency04
Jul 6, 2003 07:44 PM
no2unenolife
May 2, 2003 10:02 AM
