Increasing HP with less than $500 bucks?
I've been doing alot of research on integ mods but have found them way too expensive? Im a college student on a tight budget....got any ideas?
The best ideas i've got are
Intake
Exhaust
Throw out spare tire
Intake
Exhaust
NAWZ baby 2 big bottles...
but seriously N2O is the best bang for the buck and cheapest way to make a noticeable increase in HP
you gotta make sure the engine can handle it and have the install done right
intake & header if your running a gsr take out the petulli plates in the intake manifold. pull of that a/c and p/c belt or takem out completly.....
or squeez...."feed it the damn bottle"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumyungguy »</TD></TR><TR><TD CLASS="quote"> if your running a gsr take out the petulli plates in the intake manifold. </TD></TR></TABLE>
whats that all about??? and what kind of work does it involve??
take the intake manifold out split the manifold apart where that mid-plate is at take out the four little plates and while ur at it clean the manifold and ur throttle body. put it back on- i recemend putting the hondata intake manifold gasket you can get it from modacar.com i thing you have to call to order it. i did it on my hatch in an afternoon. crossover was louder and i could feel a difference. never got to dyno the change in hp but i would guess 8-12.
ill be doing it to my teg soon
and another thing.. you cant tell anything is done.. low pro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumyungguy »</TD></TR><TR><TD CLASS="quote">intake & header if your running a gsr take out the petulli plates in the intake manifold. pull of that a/c and p/c belt or takem out completly.....
The what plates? LOL
I think you have that mixed up w/ <U>VENTULI</U> which is a gasket made by spoon for the intake manifold. Normally seen as the "Ventuli effect" it deals w/ how air flows.
They are called secondaries, its like 4 small throttle plates.
You can also just pulled the vaccum line and they'll stay open.
btw... there is not much power increase(if any) in doing this, you'll lose bottom end.
I would go w/ a nice header w/ a 2.5" collector, 2.5" b-pipe and a 2.5" es oval.
DC JDM 4-1, Muffler shop mandrel bent b-pipe, es oval = under 500.
Cold air duct to the bottom of a stock intake box = 10 bux.
You might even be able to throw in some camgears and get some camgear tuning.
Free GO FAST Mods:
Removing Power Steering belt
Removing A/C belt
Removing Interior
Removing Rear Bumper Reinforcement Bar
Free GO FAST Mods:
Removing A/C belt
Removing Interior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">The what plates? LOL
<U>VENTULI</U> </TD></TR></TABLE>
I believe "Venturi" is the word yer lookin fer ...
<U>VENTULI</U> </TD></TR></TABLE>I believe "Venturi" is the word yer lookin fer ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r34p3r666 »</TD></TR><TR><TD CLASS="quote">
I believe "Venturi" is the word yer lookin fer ...</TD></TR></TABLE>
Keeping the secondaries open gives you no gain and you loose bottom torque.
If you only have $500 to spend I would just save it. $500 wont get you far, or much of anything Your only option would be a used Nos kit $300-350, and maybe I/H/E but there another $800-1000 depending on what brands you buy, you could buy used stuff and save $, but those bottle refills will get very expensive especially on a college budget.
$500 bucks definitely Intake & header get a 4-2-1 I drove around for about 8 months on an Intake & Header and spanked 75% of the people i raced. Now for other little things to add like dryer piping for little cold air to the intake, thats if u get a short ram cause it will be cheaper then cold air and less chance of hydrolock. Another little mod that is good of course would be a B&M FPR (fuel pressure regulator) last but not least take a little arm using advance ur timing. I did these few little mods and every GSR i have raced with same mods i'd walk cause of FPR & advance my timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznsmtboy »</TD></TR><TR><TD CLASS="quote">invest it in driving school, learning how to drive your car is the best modification you can do.</TD></TR></TABLE>
I second that advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">nos</TD></TR></TABLE>
n2o
nawz? wtf
n2o
nawz? wtf
altezzas and decals, they add 10-12whp
j/k if i were you id get my car breathing right first with intake/headers, maybe a crank pulley depending if u can save up a little extra dough
all in all, i know where your coming from, i am a poor college kid as well
best of luck with your mods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by balch104 »</TD></TR><TR><TD CLASS="quote">Use your money on a jdm oil cap
haha
</TD></TR></TABLE>haha
Go ahead and remove those plates....you'll lose a LOT of low-end torque. We dynoed my car with the IAB pinned open (essentially the same as removing the plates) and I lost about 15ft-lbs of torque until about 6000rpm!
So sure, go ahead and disable the dual-stage manifold...
Falken Azenis and the BSQ rear swaybar kit.
You'll actually be able to FEEL a difference in your car with these two mods -- as opposed to getting some mild (and expensive) bolt-ons that don't do much.
