vss obd 0 b16 ques.
Old Jan 21, 2004 | 08:49 PM
R91Si's Avatar
Default vss obd 0 b16 ques.
do you need vss hooked up for vtec to activate on obd 0? i know you do for obd 1 and obd 2...
Old Jan 21, 2004 | 08:58 PM
XJamesX's Avatar
Default Re: vss obd 0 b16 ques. (R91Si)
Yes. Just use your cable speedo. Teh ECU has to know how fast you are going to activate Vtec.
-James-
Old Jan 21, 2004 | 11:04 PM
R91Si's Avatar
i geuss ill find out tomorrow...im gettin the vss
Old Jan 22, 2004 | 05:42 AM
Vero's Avatar
Default Re: vss obd 0 b16 ques. (B18C5crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx &raquo;</TD></TR><TR><TD CLASS="quote">Yes. Just use your cable speedo. Teh ECU has to know how fast you are going to activate Vtec.
-James- </TD></TR></TABLE>
really now, I didnt know this, are D16Z6 VSS or cable?
Old Feb 6, 2004 | 09:55 AM
XJamesX's Avatar
Default Re: vss obd 0 b16 ques. (Vero)
Heres the rundown. The ECU has to have the Vehicle speed signal(VSS) to activate vtec.
The cable driven speedo's like our stock crx's have an amplifier in the actual cluster that is driven by the cable which then creates the speed signal pulse and sends it to the ECU through the Yel/red wire into pin B16 in the ECU.
The electronic speedos from 92 and up civics and 94 and up integras have the amplifier attached directly onto the speedo gear that is in the tranny. This is what creates the signal pulse and sends the signal to the cluster and the ECU.
This is a pic of a speedo gear from a 99 integra. The black part is the amplifier that creates the signal which send it to the ECU and cluster.
-James-
keko656
Aug 15, 2009 10:13 PM
goldenhatch13
21
Nov 10, 2008 10:51 PM
jamesracer
Mar 30, 2007 07:31 PM
spaceman
Apr 8, 2004 11:30 AM
solman74
Sep 10, 2003 09:59 PM
