What is this??? (massive)
Old Jan 21, 2004 | 06:49 PM
TylerB's Avatar
Default What is this??? (massive)
I might be wrong on this but i just wanted to make sure, i went through the wiring diagrams and i believe this goes to the tach...am i right? or way off....
Old Jan 21, 2004 | 06:52 PM
the DR.'s Avatar
Default Re: What is this??? (94prelude)
if you follow those wires, they go under the distributor to a 2 pin connector on other side of the distributor, and you are correct - for the tach.
Old Jan 21, 2004 | 06:53 PM
shorty91's Avatar
haha rag racing! im pretty sure it does
Old Jan 21, 2004 | 07:05 PM
TylerB's Avatar
Default Re: What is this??? (shorty91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty91 &raquo;</TD></TR><TR><TD CLASS="quote">haha rag racing! im pretty sure it does</TD></TR></TABLE>
nah, thats to cover my "secret" motor. ha, i wish, its a 70hp piece of ****.
Old Jan 21, 2004 | 07:08 PM
MrTodd's Avatar
No.
That 2pin connector that those wires lead to is for the ignition coil. One wire is positive, and the other is a ground. That has nothing to do with the tach. On the 7pin connector for the distributor, there should be 2 white wires (if it's an Si or HF), one fatter than the other. This fatter white wire sends the RPM signal to the ECU. I'm not sure exactly where/how the tach pics it up at...
Old Jan 21, 2004 | 07:24 PM
Red_Si's Avatar
Default Re: What is this??? (MrTodd)
if your installing a tach, take off the dizzy cap and unscrew the positive post to the coil, put your wire in thier and screw it back down. works like a charm.
Old Jan 21, 2004 | 07:31 PM
TylerB's Avatar
its a std, and its a blue wire....
Old Jan 21, 2004 | 07:32 PM
the DR.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">No.
That 2pin connector that those wires lead to is for the ignition coil. One wire is positive, and the other is a ground. That has nothing to do with the tach. On the 7pin connector for the distributor, there should be 2 white wires (if it's an Si or HF), one fatter than the other. This fatter white wire sends the RPM signal to the ECU. I'm not sure exactly where/how the tach pics it up at...</TD></TR></TABLE>
sorry, i stand corrected, but i do know you hook up aftermarket tachs to that blue wire (2pin connector)
Old Jan 21, 2004 | 07:35 PM
MrTodd's Avatar
Default Re: What is this??? (the DR.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DR. &raquo;</TD></TR><TR><TD CLASS="quote">
sorry, i stand corrected, but i do know you hook up aftermarket tachs to that blue wire (2pin connector)</TD></TR></TABLE>
Ooops, than I am wrong.
Old Jan 21, 2004 | 08:17 PM
90civichbsi's Avatar
it would probably alot cleaner to just splice into the blue wire leading to the stock tach, and alot less wiring to do.
its the #1 pin on the 8p connector on the back of your cluster. just look for the solid blue wire.
that is to say if your installing an aftermarket tach.
Old Jan 24, 2004 | 07:33 PM
TylerB's Avatar
Default Re: What is this??? (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">it would probably alot cleaner to just splice into the blue wire leading to the stock tach, and alot less wiring to do.
that is to say if your installing an aftermarket tach.</TD></TR></TABLE>
Its an std, so it doesnt have a tach, im getting a cluster from the si which has the tach, can someone explain how to hook it up? And also, while taking my stock cluster, i found a amber piece of plastic screwed in on top of the cluster, if i want to change the color of my gauge lights is this what i would change?
Old Jan 24, 2004 | 07:37 PM
Hondasaurs's Avatar
"BLUE" wire
Old Jan 24, 2004 | 07:43 PM
JonGP4's Avatar
sorry but u are wrong.. the blue wire is the "tach" wire.. yes they goto the coil as well, but it also goes to the tach as well.. again.. the blue wire from that 2 pin connector is the tach wire..
if u have a std, or DX model without a tach.. the wires are already there.. just plug in the gauage and the tach will start working
Old Jan 24, 2004 | 07:48 PM
Hondasaurs's Avatar
He asked if this was the tach wire which is the ...."BLUE" wire
Old Jan 24, 2004 | 07:58 PM
TylerB's Avatar
Default Re: What is this??? (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">sorry but u are wrong.. the blue wire is the "tach" wire.. yes they goto the coil as well, but it also goes to the tach as well.. again.. the blue wire from that 2 pin connector is the tach wire..
if u have a std, or DX model without a tach.. the wires are already there.. just plug in the gauage and the tach will start working </TD></TR></TABLE>
so just plug it into where my gas gauge and water temp plug in is now?
Old Jan 24, 2004 | 08:15 PM
JonGP4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">
so just plug it into where my gas gauge and water temp plug in is now?</TD></TR></TABLE>
WTF? just take out ur gauge cluster, and put in the one from at Si with a tach.. if u car is 88-89 then make sure ur gauage cluster is from a 88-89 if its 90-91 then u need one from 90-91.. they plug right in.. no need for any other wiring as long as u keep the years i just said right.
Old Jan 25, 2004 | 08:58 AM
hionvtecxda6's Avatar
if u car is 88-89 then make sure ur gauage cluster is from a 88-89 if its 90-91 then u need one from 90-91.. they plug right in.. no need for any other wiring as long as u keep the years i just said right.</TD></TR></TABLE>
Haleiwa-Brando
Dec 26, 2007 09:45 PM
jdmcivicferio
Aug 8, 2006 10:41 AM
blackEF
Feb 2, 2004 04:23 PM
OutLuDeD
Mar 1, 2003 07:50 AM
Duckz
Aug 12, 2002 10:18 PM
