Starter Direct Ground? Need some help
Old Jan 21, 2004 | 06:39 PM
mattjohnston's Avatar
Default Starter Direct Ground? Need some help
Currently, unless I connect a DIRECT wire from the body of the starter to the negative terminial of the battery, nothing will happen.
Without a direct connection, no lights, blinkers, cranking NOTHING..
I have new ground cables from the trans to the body, the valve cover to the body, everything. New bolts too. I have ground paint off the body. But unless I make a direct connection from the starter body to the battery, no dice!
Anyone have any ideas. I am super frustrated.
Old Jan 21, 2004 | 11:42 PM
Stripped Honda's Avatar
99-0104
Default Re: Starter Direct Ground? Need some help (mattjohnston)
something is wrong with your ground wires i would take them off and check them again
Old Jan 22, 2004 | 05:02 AM
Default Re: Starter Direct Ground? Need some help (Stripped Honda)
Grounds are all good. Brand new 2 Gauge cables, no paint on the connecting points.
Anything else it could be?
Old Jan 22, 2004 | 06:29 AM
Daemione's Avatar
So it worked before your new grounds? Are you still using all of the stock ground locations? Is it possible the wiring harness for the starter was damaged?
Old Jan 22, 2004 | 07:22 AM
Default Re: Starter Direct Ground? Need some help (Daemione)
Harness is fine. I just re-installed my motor. All the cables are fine. Voltage through the cables is fine.
But, unless I connect a wire from the body of the starter to the battery, there is NO electrical.
Is there any possibility the alternator is involved in this?
J1MMY420
May 16, 2014 08:46 PM
GoBrowns
Oct 3, 2013 02:56 AM
digitalvice
Jan 2, 2013 08:47 AM
bayoufrogg
Oct 24, 2006 08:18 PM
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
