mpfi swap with d16z6 intake manifold
Old Jan 21, 2004 | 04:23 PM
green91's Avatar
Default mpfi swap with d16z6 intake manifold
ive searched but havent found any info pertaining to my set up... im doing the mpfi swap on my dx, but have some questions about using a d16z6 intake manifold. first off, the z6 has a MAP sensor built into the throttle body i believe. which map should i use... on the TB or the one mounted on the firewall? i am also curious as to how to run the vacuum lines and such. thanks
Old Jan 21, 2004 | 04:41 PM
FAST AS's Avatar
Default Re: mpfi swap with d16z6 intake manifold (green91)
me to bump
Old Jan 21, 2004 | 05:09 PM
green91's Avatar
i hope someone knows... i dont wanna have to use an a6 mani
Jockobo's Avatar
Default Re: mpfi swap with d16z6 intake manifold (FAST AS)
u can use whichever map sensor u want...vacuum lines from what i remember there will be one that's from the firewalll that will not have a place to go...unless u tee it or something...
Old Jan 21, 2004 | 05:26 PM
green91's Avatar
you wouldnt happen to have a pic or know someone that does would you?
Old Jan 22, 2004 | 09:59 AM
green91's Avatar
bump
Old Jan 22, 2004 | 05:17 PM
FAST AS's Avatar
Default Re: (green91)
bump
Old Jan 22, 2004 | 05:23 PM
green91's Avatar
Default Re: (FAST AS)
ive even got pics now to help answer my q's! where do the hoses that connect to 1,2,3, and 4, respectively, go?
Modified by green91 at 6:41 PM 1/23/2004
Old Jan 23, 2004 | 02:28 PM
Jockobo's Avatar
2 to 3 and 1 to the block...
Old Jan 25, 2004 | 07:29 PM
green91's Avatar
Default Re: (Jockobo)
alright guys.. ive got my mpfi running with d16z6 manifold. i used stock dx IAT. my tb doesnt have the map sensor in it, so i used the stock dx map sensor and purge evap selenoid. 91 Si pcv valve. #1 goes to the coolant nipple off the tube that goes to the water pump. #2 goes to #3, and #4 goes to the coolant nipple on top of the manifold. i plugged off the coolant nipple underneath the runners closest cyl #4. i did not need any T's or anything for the vacuum lines... was pretty simple once i started doing it.. hopes this helps! also, it made my intake hellaciously louder and the car sounds fast as long as your not watching it drive by or looking at the speedo ..lol. but a very worthwhile mod!
Old Feb 13, 2004 | 10:05 PM
sohcvtec66
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">alright guys.. ive got my mpfi running with d16z6 manifold. i used stock dx IAT. my tb doesnt have the map sensor in it, so i used the stock dx map sensor and purge evap selenoid. 91 Si pcv valve. #1 goes to the coolant nipple off the tube that goes to the water pump. #2 goes to #3, and #4 goes to the coolant nipple on top of the manifold. i plugged off the coolant nipple underneath the runners closest cyl #4. i did not need any T's or anything for the vacuum lines... was pretty simple once i started doing it.. hopes this helps! also, it made my intake hellaciously louder and the car sounds fast as long as your not watching it drive by or looking at the speedo ..lol. but a very worthwhile mod! </TD></TR></TABLE>
hey its like night and day isnt it, my buddy got a dx, and we did the MPFI SWAP,with a6 dizzy,a6 im,a6 cam and cam gear, re-wire, pm6 ecu, quit simple swap.. good clutch, its like night and day from dpfi to mpfi...good luck
Old Feb 14, 2004 | 04:19 PM
green91's Avatar
Default Re: (sohcvtec66)
definately... i think that the z6 manifold makes a noticable difference over the a6 manifold also. the car sounds fast now, as long as you arent watching it! lol but yeah it was worth it.
1sikhatch
Feb 10, 2007 09:37 AM
ftwlucky13
Feb 2, 2005 10:33 PM
rasta420
Oct 26, 2004 10:10 AM
SLowCrx
Apr 8, 2004 03:17 PM
Smoothy
Dec 24, 2002 09:59 PM
