I need help with friends Toyota alarm... it won't shut off...
Old Jan 21, 2004 | 03:31 PM
Se-rv-Tak's Avatar
Default I need help with friends Toyota alarm... it won't shut off...
My friend has a 96 Toyota Celica, with some aftermarket alarm called, Mirage model# 9500 and of coarse they went out of buisness, they no longer exist.
My friend, disconnected his battery... and now the car is armed, and will not disarm itself... and the orginal remote he had for it, broke. what can he do to fix this problem? anything in a wiring since that he can disconnect.... or anything? please help me out, he's a really good friend of mine, even though he doesn't drive a honda.. lol
Old Jan 21, 2004 | 06:28 PM
B18C_EJ8's Avatar
Cut the horn wire for now, or unplug it...
Old Jan 21, 2004 | 09:11 PM
Se-rv-Tak's Avatar
Default Re: (B18C_EJ8)
Im not sure he is going to bother with that..... his alarm has an automatic starter kill switch... when it's armed it won't start.
Old Jan 22, 2004 | 07:18 AM
shauniewalnuts's Avatar
Default Re: (Se-rv-Tak)
take out the brain of the alarm
Old Jan 22, 2004 | 08:43 AM
Se-rv-Tak's Avatar
Default Re: (NAPA182)
he took out the brain, and it still doesn't work...... what fuse? should he pull?
Old Jan 22, 2004 | 09:07 AM
MassMayhem's Avatar
Default Re: I need help with friends Toyota alarm... it won't shut off... (Se-rv-Tak)
Sounds like the starter wire was cut and the starter-kill relay wired "normally open" , meaning the relay needs to be energized to start the car. Check the starter wire to make sure its connected properly.
Old Jan 22, 2004 | 09:16 AM
Se-rv-Tak's Avatar
Default Re: I need help with friends Toyota alarm... it won't shut off... (MassMayhem)
ok... let me find the link my friend has... he has pictures..
Old Jan 22, 2004 | 09:18 AM
Se-rv-Tak's Avatar
ok nevermind, thanx for ur help guys... he fixed it...
quiambao1180
Jun 21, 2004 04:17 PM
cyvic
Audio / Security / Video
Aug 3, 2003 06:51 PM
94TealCivic
Jul 12, 2003 01:57 AM
Ludeboi
10
Oct 7, 2002 05:14 PM
Weston
Jan 30, 2002 04:01 PM
