FS: SLR Camera's
Old Jan 21, 2004 | 03:10 PM
3.3.3's Avatar
Default FS: SLR Camera's
Canon EOS Rebel 35mm Single Lens Reflex Camera
(Auto and Manual Settings)
Camera Type: 35mm focal plane shutter SLR (Single-Lens Reflex) autofocus / autoexposure camera with built-in motor drive and retractable flash.
Lens Mount: Canon EF mount (electronic signal transfer system).
Usable Lenses: Canon EF lenses.
Viewfinder: SLR-type, eye-level roof prism mirror gives 90% vertical and horizontal coverage of actual picture area and 0.70x magnification with 50mm lens at infinity.
Mirror: Quick-return half mirror.
Standard Diopter: Adjusted to -1. (18.5mm eye relief)
Dioptric Correction: -2.5 - +0.5 dpt.
Depth-of-Field Preview: Enable with depth-of-field preview button.
Focusing Screen: Fixed, full-surface new laser-matte screen marked with focusing points.
Viewfinder Information: Numbers and symbols displayed by LCD at bottom of viewing area. (Yellow-Green)
1. Shutter speed (If unsuitable blinks at 2 Hz as a warning.)
2. Aperture (If unsuitable blinks at 2 Hz as a warning.)
3. :Indicates AE lock or FE lock (Partial metering at center.)
4. :Exposure level scale with dot indicators in 1/2-stop increments. (?2 stops)
5. :Lights when flash is ready; blinks at 2 Hz if flash range is ineffective during FE lock.
6. :Lights during high-speed sync. (FP flash)
7. :In-focus indicator. (Blinks at 2 Hz if focus cannot be achieved.)
Shutter: Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control. (Curtain speed: 6.3ms / 24mm)
Shutter Speeds: 30 to 1/2000 sec., Bulb; X-sync at 1/90 sec. Can be set in 1/2-stop increments.
AUTOFOCUS
AF Control System: TTL-SIR (Secondary Image Registration) CMOS sensor ()
Focusing Point Selection: The focusing point can be selected by camera (Automatic) or by user (Manual).
Focus Modes:
1. AutofocusOne of the following two AF modes is set automatically depending on the picture-taking mode. The shutter does not release until focus is achieved.
a. One-Shot AF: Autofocus locks when focusing is achieved.
b. Predictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
c. AI Focus AF for automatic switching between One-Shot AF and predictive AF for moving subjects.
2. Manual FocusSetting the lens' focus mode switch to MF enables manual focusing with the focusing ring.
Focus Operation: Autofocus is activated by pressing the shutter button halfway.
AF Working Range: EV1-18 (at ISO100)
AF-assist Beam: Automatically emitted when necessary and aimed at the area covered by the active focus point.
EXPOSURE CONTROL
Light Metering:
1. TTL full-aperture metering using 35-zone SPC (Silicon Photocell). Three metering patterns available.
a. 35-zone Evaluative Metering.
b. Central partial metering which covers approximately 9.5% of finder area.
c. Center weighted average metering (Set automatically in M mode.)
2. E-TTL: 7-point, 35-zone pre-flash metering using Speedlite 550EX, 420EX, or 220EX.
3. A-TTL, TTL Flash Metering: off-the-film, 3-zone A-TTL autoflash linked to focusing points, 3-zone TTL autoflash metering.
Metering Range: EV 1-20 (with 50mm f/1.4 lens at ISO 100)
Exposure Modes:
1. Intelligent program AE with variable shift.
2. Shutter speed-priority AE
3. Aperture-priority AE
4. Auto DEP
5. Full Auto (Intelligent program AE, unshiftable)
6. Programmed Image Control Modes: Portrait, Landscape, Close-up, Sports, Night Portrait and Flash Off
7. E-TTL program flash AE
8. A-TTL program flash AE
9. TTL program flash AE
10. Metered Manual
Exposure Compensation:
1. Auto Exposure Bracketing (AEB) up to ?2EV in 1/2 steps.
2. Manual exposure compensation up to ?2 EV in 1/2 steps.
3. Unavailable in the Full Auto and Programmed modes.
Multiple Exposure: Up to 9 exposures can be preset. Automatically clears upon completion. Cancelable midway.
FILM TRANSPORT
Film Speed Setting: ISO 25-5000 automatically set in 1/3 step increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 step increments.
Film Loading: Automatic prewind system. After film positioning and back cover closure, the film automatically winds to the 1st frame.
Film Transport: Single-frame advance or continuous advance set automatically according to the picture-taking mode.
Film Wind: One of two modes can be set: Single Frame and Continuous. (In Continuous Mode, with AF locked, approximately 2.5 fps and in AI Servo AF Mode, approximately 1.3 fps.)
Film Rewind: Automatically rewinds at the end of roll. Midroll rewinding possible.
Quiet Film Transport: Film winding sound level: Approximately 60dB
Film Transport Confirmation: By up/down counting of frame counter in LCD panel.
BUILT-IN FLASH
Type: Built-in, retractable TTL autoflash head in the pentaprism. Auto pop-up and serial-controlled.
Guide Number: 39 ft / 12 m (ISO 100)
Flash Coverage Angle: Covers the angle of view of 28mm lens.
Recycling Time: Approximately 2 seconds. The icon lights in viewfinder when ready
Flash Duration: / Color Temperature 1ms or less / equivalent to daylight.
Flash Shooting Distance Rangewith EF 28-90mm f/4-5.6 Lens and 400 ISO Film )
Wide: 28mm 3.3 ft~27.9 ft
Tele: 90mm 3.3 ft~19.6 ft
Red-Eye Reduction: Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved.
POWER SOURCE
Battery: Two CR2 lithium batteries housed inside the camera grip.
Battery Check: Battery level is displayed by the battery level indicator on the LCD panel. Battery level is indicated in one of four levels.
SHOOTING SPECIFICATIONS
Shooting Modes: Full Auto, Portrait, Landscape, Close-up, Sports, Night Scene, Flash Off, Intelligent Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, Manual Exposure, Automatic Depth-of-Field AE
Continuous Shooting: Approx. 2.5 images/sec.
Dimensions: 5.12 (W) x 3.46 (H) x 2.52 (D) in. / 130 (W) x 88 (H) x 64 (D) mm
Weight: 12.9 oz. / 365 g without batteries
Extras w/ Camera-28mm Original Lens
-Quantaray Wide Angle Lens ($200)
-Quantaray Circular Polarizer Filters for both lenses
-Green Filter for BW
-Pink Filter for BW
-Two carrying bags
-Tripod
-Gel neck Strap
-------------------------------$300---------------------------------
Kiev Medium Format Camera
Single Lens Reflex outfit
uses 120-220 film
Film type 120 roll film
Image size (Kiev 60) 2-1/4 x 2-1/4 inches (6 x 6 centimeters)
Image size (Kiev 645) 2-1/4 x 1-5/8 inches (6 x 4.5 centimeters)
Number of exposures (Kiev 60) 12 exposures
Number of exposures (Kiev 645) 16 exposures
Lens mount C-type breech-lock bayonet (Kiev 60/Pentacon Six/Praktisix/Exakta- 66)
Shutter type Black cloth coil focal plane shutter, horizontal traverse
Shutter speeds (seconds) 1/1000, 1/500, 1/250, 1/125, 1/60, 1/30, 1/15, 1/8, 1/4, 1/2, and B (manual)
Mirror Lock Up Available on the Kiev 60 MLU version
Flash synchronization type X sync, through hot shoe and PC connection
Maximum flash shutter synch speed 1/30th second
TTL-metered prism power source 4.5 volts (A76, LR44, or equivalent), 3 required
Tripod screw mount One 3/8-inch (European style) mount
Size 6.8 x 6.2 x 5.5 inches
Weight 4.6 lb (2.1 kg)
List Price - $349
--------------------My Price $150 For the complete kit--------------------
PM or post with interests....
Max
Old Jan 22, 2004 | 07:34 AM
3.3.3's Avatar
Default Re: FS: SLR Camera's (makS)
ttt
best deal around
Old Jan 22, 2004 | 07:44 AM
b18bEG's Avatar
bump for a fellow canon owner
Old Jan 23, 2004 | 08:07 AM
3.3.3's Avatar
Default Re: (b18bEG)
thanks....trying to get some $$ to get the car running
Old Jan 23, 2004 | 08:50 AM
3.3.3's Avatar
Default Re: (makS)
ALSO OPEN FOR TRADES....ANY EG AFTERMARKET OR JSPEC CRAP
Wh0 Iz UNREAL07
Jun 3, 2009 05:47 PM
sloweredcivic
Feb 18, 2006 08:46 AM
