h22 tranny question
Old Jan 21, 2004 | 01:59 PM
92eg6's Avatar
Default h22 tranny question
if i was to get an h22 auto swap, and i didnt get the tranny, i would be able to just get a 5 spd tranny?, and what 5spd tranny's fit? and which would be best?
the swap would most likely go on an eg or ek hatch, if it makes a diff, i would prefer an ek
Old Jan 21, 2004 | 02:18 PM
DxTrix's Avatar
Default Re: h22 tranny question (92eg6)
pm sent
Old Jan 21, 2004 | 03:02 PM
92eg6's Avatar
Default Re: h22 tranny question (DxTrix)
help
Old Jan 21, 2004 | 04:05 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">if i was to get an h22 auto swap, and i didnt get the tranny, i would be able to just get a 5 spd tranny?, and what 5spd tranny's fit? and which would be best?
the swap would most likely go on an eg or ek hatch, if it makes a diff, i would prefer an ek</TD></TR></TABLE>
you'll have to get a manual h22 ecu. but yes, if you get the flywheel, clutch, and manual tranny with the cables, then yes, it can be done just like any normal h22a swap.
Old Jan 21, 2004 | 04:47 PM
92eg6's Avatar
Default Re: h22 tranny question (poison)
ok, then if i get an h22 ecu, w/a tranny, shift linkage etc. from a h23, it will fit?, cause the h22 lsd trannys, are too expensive
Old Jan 21, 2004 | 04:54 PM
poison's Avatar
yes, H23 trannies, as well as the accord trannies will all work. shifter assembly, cables, and everything. You need an H22A manual ECU, or a chipped P28, chipped P72, etc.
Old Jan 21, 2004 | 06:19 PM
92eg6's Avatar
alright, your a big help,
now do you have any advise on what wold be the best tranny, prelude si?
im purchacing the, legit , swap for 600, good price??
Old Jan 21, 2004 | 07:00 PM
Newman's Avatar
New User
If you can't find a H22 or H23 tranny, you can also use a F-series 5-spd tranny from an Accord. But you have to use the 94+ transmission as the 90-93 tranny will still bolt to the H22 block, but the mounting points for the tranny mount will not line up with an aftermarket mount kit.
Accord01324
Apr 19, 2007 05:09 PM
T"u"Rtle
Oct 30, 2005 09:33 PM
DsMh22
15
Apr 23, 2004 10:07 AM
