Anyone know where this goes?
I took my b18c1 out of my car, and while taking it out, this washer fell out. I have no Idea where it goes, and I want to make sure I get it in before I put the motor back in my car.
would you put it by a ruler and also a side shot? I can't get a good feeling for the size of it. It looks like maybe for a bolt for a mount, but maybe not.
sorry buzz ur pretty much S.O.L. i know i cant and pretty sure no one else will be able to tell where that goes. try and think of what olts u have taken out that fit that washer. good luck
If I'm not mistaken, that washer slides on the the little post where the torsion bar of your shift linkage connects to the tranny. Not the actual shifting rod, the other bar with the circular end. It just slides on before you connect that bar. I don't think you really need it. But i could be wrong.
Or this: http://www.acuraparts247.com/s...ch=no
If anything try going to an Acura dealer and ask a knowledgeable tech.
this is pretty much impossible to find out (unless your a GSR guru) It looks like a washer for a motor mount to me (just a guess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegrayghost »</TD></TR><TR><TD CLASS="quote">If I'm not mistaken, that washer slides on the the little post where the torsion bar of your shift linkage connects to the tranny. Not the actual shifting rod, the other bar with the circular end. It just slides on before you connect that bar. I don't think you really need it. But i could be wrong.</TD></TR></TABLE>
i agree with this guy
that is exactly what it looks like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX i GSR »</TD></TR><TR><TD CLASS="quote">
that is exactly what it looks like</TD></TR></TABLE>
You know what... it did fall from somewhere near the tranny. I put the shiflinkage on already, is there supposed to be 2 washers, one each side of that circular rod? I only have 1 on there.
Yep, that looks like what it is guys, thanks a lot http://www.acuraparts247.com/s...ch=no
civic4life8045
Feb 7, 2013 08:00 PM
weiRtech
Welding / Fabrication
Apr 2, 2007 10:21 AM
krysmagnetic83
May 18, 2005 06:40 PM
