High Compression Tuning(running) ?s.
I am going to be rebuilding my gsr in a month or two with JDM ITR pistons(the spoon ones) and a spoon 2 layer headgasket. Im guessing that will raise my compression to around 11.6:1....Besides runnning on 93 octane, what else should I do? Ignition timing at 16? Or do I need it lower? Should I get colder spark plugs? I am trying to avoid detonation....I have a VAFC too if you guys have any fuel tuning advice....thanks a lot.
i think he's refering to low compression engines you are suppose to turn back the timing.
BTW, no need to dial down the ignition timing in a low CR engine.
What are you using to manage your fuel? Because I have been thinking about running CTR pistons (12.2:1) on 92 octane. But will I need to adjust my fuel or just my timing to have no signs of detonation?
You are correct sir. WIth 12.2:1 CR I run 18 degrees timing and 92 octane with -0- ill effects.
My point is that your reply implied in a way that 12.x compression is ok on 92 octane <u>without</u> mods to the fuel system - which is what the guy was asking about. Just trying to prevent misconceptions that's all.
There's at least two or three cars locally that run 12:1 or higher daily driven on stock injectors. Just a mapped ECU and fuel pressure are the only fuel/ignition mods. All of these motors are hitting well over 185/130 at the wheels.
It's just a matter of tuning it right. No rookie tuner will be able to run 12.5:1 on his first motor build experience without ill effects. Just takes a little experience is all.
But to answer your question man, if it'll make you feel safer running step colder plugs then go for it. If I were you I would let it eat. Run 19-20 degrees timing and add fuel from there. I highly doubt you will detonate at 11.5:1
HellaFab
13
Sep 21, 2011 04:10 PM
JonDick
Dec 20, 2010 10:27 PM
