hondata or toda reflashed ecu?
Old Jan 21, 2004 | 08:26 AM
NightHawkC5's Avatar
Default hondata or toda reflashed ecu?
Which gives you better results with the toda engine package? Ive head getting the cams a nd using a hondata stage 4 reflash is better?
Old Jan 21, 2004 | 01:05 PM
raph's Avatar
Of course the Toda reflash.
Old Jan 21, 2004 | 01:41 PM
Peking's Avatar
Default Re: (raph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raph &raquo;</TD></TR><TR><TD CLASS="quote">Of course the Toda reflash. </TD></TR></TABLE>
Um... Yeah
Old Jan 21, 2004 | 01:42 PM
njandrewg's Avatar
Default Re: (Peking)
I believe u can only get the toda flash if u acutally buy their cams
ITR_1211's Avatar
I believe the wait with Toda is alot more than Hondata. Correct me if i'm wrong but I heard your ECU gets shipped to Japan to get flashed
Old Jan 21, 2004 | 01:56 PM
DC5ITR329's Avatar
Default Re: (Darryl Musashi)
They are flashed at hondata.
Old Jan 21, 2004 | 03:15 PM
ITR_1211's Avatar
Default Re: (aznbo1626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 &raquo;</TD></TR><TR><TD CLASS="quote">They are flashed at hondata.</TD></TR></TABLE>
I was talking about Toda
Old Jan 21, 2004 | 04:01 PM
pints99's Avatar
hondata actually does the flash for the toda engine kit. So it is flashed in CA, wherever hondata is located. Toda will obviously net you more HP since you are adding in more aggressive cams, but look at the pricing. 600 vs 2350. If you've got the dough to drop on Toda then more power to you. If not then Hondata I've heard is a great mod for the money.
Old Jan 21, 2004 | 07:03 PM
Peking's Avatar
Default Re: (pints99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pints99 &raquo;</TD></TR><TR><TD CLASS="quote">hondata actually does the flash for the toda engine kit. So it is flashed in CA, wherever hondata is located. Toda will obviously net you more HP since you are adding in more aggressive cams, but look at the pricing. 600 vs 2350. If you've got the dough to drop on Toda then more power to you. If not then Hondata I've heard is a great mod for the money.</TD></TR></TABLE>
Yeah, but it come with the Toda package. So getting it by itself doesn't seem good IMO.
Old Jan 22, 2004 | 06:13 PM
rsxmachine's Avatar
my ecu is on its way to CA right now to upgrade from Hondata-4 to Toda flash. according to them the engine won't run quite right with Toda cams and Hondata-4 program. Obviously the Toda flash is better tuned for their cams, plus you get the higher redline and dual VTEC crossover function.
Old Jan 22, 2004 | 11:03 PM
FREAKquency04's Avatar
Default Re: hondata or toda reflashed ecu? (NightHawkC5)
hondata most definently
Old Jan 23, 2004 | 12:30 AM
K20EG's Avatar
Default Re: (rsxmachine)
I heard the mugen rsx ecu is worth more ponies
MJ23FE
Feb 25, 2003 08:00 PM
90accord1
Aug 1, 2002 08:49 PM
Hard2Find
Jul 6, 2002 12:00 PM
