TL S sway bars
Old Jan 20, 2004 | 07:52 PM
Legendaryyaj's Avatar
Default TL S sway bars
Ok i posted this in the Tech thread but got nothing so heres my question to you guys. How hard is it to do the install by myself with regular tools? I found a set of frotn and rear for real cheap and was thinking about picking them up. I dont want to go stripping anything apart if i have to, especially with the suspension. You guys recommend DIY or take it to the shop?
Old Jan 20, 2004 | 07:55 PM
The_Todd's Avatar
Farts in the shower
Default Re: TL S sway bars (Legendaryyaj)
DIY, should be that hard with regular tools, just replace existing (if you have them) and add new tls sways, if your car doesn't come with them make sure you at least get all hardware fo application and should be able to figure it out via how it was layed out on the tls or via the search function...i could have sworn this was brought up a while ago, I am assuming for 6th gen.
Old Jan 20, 2004 | 07:56 PM
iam7head's Avatar
straight swap, nothing special needed.
a word of wisdom from experience, spray the anti-sway bar end link's nuts with Wd40
you need socket rachet, hex key..that's all
wd40 and silicone lube for the mounting bracket
been there done that, you'll love the mod.
one more things, ask for the stock rubber/poly urtherne bushing with the metal bracket
Old Jan 20, 2004 | 07:58 PM
iam7head's Avatar
Default Re: TL S sway bars (iam7head)
btw i have 6th gen coupe with stock rear antibar.
i picked up tl-s(same as cl-s) front and rear antisway bar and diy it myself.
just get the car in the air and everything is lay out for joo
Old Jan 20, 2004 | 08:00 PM
Ok I got a 6 gen. and i thought all cars came with sway bars, jus different sizes. Correct me if im wrong VRD.
Old Jan 20, 2004 | 08:01 PM
The_Todd's Avatar
Farts in the shower
Well they do, I must have been hitting the crack pipe a bit much....my bad.
Old Jan 20, 2004 | 08:14 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">Ok I got a 6 gen. and i thought all cars came with sway bars, jus different sizes. Correct me if im wrong VRD.</TD></TR></TABLE>
front bar is pretty standard long time ago.
5th gen lx, dx dont have rear sway, 6th gen dx dont have sway neither, newer base model eclipse dont.
Old Jan 21, 2004 | 10:55 AM
I have a lx 4dr so everything just bolts up right, take off the old and reuse the old nuts and bolts and install new sway bars? Nothing to compress or force on?
Old Jan 21, 2004 | 11:18 AM
The_Todd's Avatar
Farts in the shower
I would say the sway bar is bigger than the one on your stock, to be on the safe side I would grab the holders and bushings. I dont think your stock holders and bushings will fit, but stock bolts on the body will work.
immajackuup
Apr 22, 2009 12:25 PM
B18-Series
Suspension & Brakes
May 3, 2006 11:32 PM
Legendaryyaj
Jan 20, 2004 06:57 PM
CRX7
Oct 5, 2002 08:07 PM
HuGEN
Nov 26, 2001 10:53 AM
