NSX calipers on stock ITR rotors?
I was just told that because of the legend rotors being thicker than stock ITR, I need a longer bolt and washer in order to bolt up the NSX calipers to a stock ITR brake setup (pads and rotors).
Did any of you guys use nsx calipers with stock itr rotors? I don't plan on getting legend rotors till after these stock itr warp at the track.
https://honda-tech.com/zerosearch - i hope you're kidding....
https://honda-tech.com/zerothread?id=629875
here's the mass thread on nsx calipers.
Everyone is running Legend GS rotors but I don't see any info pertaining to keeping the stock itr rotors. Maybe
on me
on me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Everyone is running Legend GS rotors but I don't see any info pertaining to keeping the stock itr rotors. </TD></TR></TABLE>
Thats because they are the same..........
http://www.napaonline.com
Attributes:
Attributes: Rotor - Front
Diameter: 11 5/64''
# of Bolt Holes: 5
Bolt Circle Dimensions: 4.50''
Discard Thickness: 0.827''
Comments:
. Type R
Attributes:
Diameter: 11 5/64''
# of Bolt Holes: 5
Comments:
- Legend (LS)
Attributes:
Diameter: 11 3/32''
# of Bolt Holes: 5
Discard Thickness: 1.023''
Comments:
- Legend (GS)
Attributes:
Diameter: 11 5/64''
# of Bolt Holes: 5
Comments:
. Type R
Attributes:
Diameter: 11 5/64''
# of Bolt Holes: 5
Comments:
- Legend (LS)
Attributes:
Diameter: 11 3/32''
# of Bolt Holes: 5
Comments:
- Legend (GS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Stock ITR = 32mm
Legend GS = 38mm </TD></TR></TABLE>
NOT true. ITR rotors are 23mm thick, and Legend GS/NSX rotors are 28mm thick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">I am looking for info on how to bolt these onto stock ITR 23mm rotors. </TD></TR></TABLE>
RTFT!!!!!
Rodney even took pictures and detailed description of his setup!
RTFT!!!!!
I just read through it again and rodney seems to have some good info but no specifics.
Just posted that he is using stock itr everything with the nsx NA1 calipers.
But there is a problem that you loose 5mm of pad life but gives you more clearance.
I just want this setup to fix exactly like stock until I pick up the GS rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Just posted that he is using stock itr everything with the nsx NA1 calipers. </TD></TR></TABLE>
Thats exactly what you want, isnt it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Did any of you guys use nsx calipers with stock itr rotors? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">But there is a problem that you loose 5mm of pad life but gives you more clearance. </TD></TR></TABLE>
You should throw away the pads at 5mm left anyways. Besides what you lose in the use of pad thickness, you will gain back in evenly worn pads at the track. Its a wash in pad life.
<----------- *bangs head* breathes *bangs head* serenity now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">True that. This will suffice till they warp at the track.
How's this to bake your noodle... rotors dont "warp"....
In fact we had this same problem, commonly diagnosed as "warped" rotors... was just a material problem. Cleared up after 4 days of street driving.
</TD></TR></TABLE>How's this to bake your noodle... rotors dont "warp"....
Was this using the same pads as the ones that were tracked?
How were the rotors when they were hot at the track?
I have heard of this "ghost" warping...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Was this using the same pads as the ones that were tracked? </TD></TR></TABLE>
Yes. We didnt even take the wheels off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">How were the rotors when they were hot at the track? </TD></TR></TABLE>
Thats where the problem showed up. Got worse all day sunday. Then went away after some street driving.
i'm running the legend calipers..but it didn't come w/the legend brackets..so i have to use the stock itr brackets...thus running ITR rotors.
i forgot who, but someone here on HT was nice enough to send me their old pads for free. i took it to a machine shop and had them grind it down to exactly 5mm thick (to counter the 5mm difference). rubbed the grease all over it..and put it inbetween the caliper piston and the actual (new) brake pad. works like a charm.
sidenote: does anyone know if the stock ITR brackets can handle the larger Legend rotors? i was told it wouldn't
This sounds like a bad idea. A very bad idea in fact. I would not recommend doing this. If you've ever seen brake failures or things come apart at high speed....
thanks for the input RJ!
i agree i thought it was a bad idea..but honestly it's been holding fine, even after a track day... but a friend of mine who runs a lot of track days (and also a mechanic) w/the same setup. i figure if it's fine for him, it would definitely be fine for me.
i wouldn't know how it would fall apart if it's secured in the caliper and is the exact same shape/material as the backing of a brake pad?
