Coilover Noise.
Old Jan 20, 2004 | 05:45 PM
H22SiRaccord's Avatar
Default Coilover Noise.
Ok i just put maxspeed coilovers on my 95 accord. I still have stock struts and shocks. The problem i am having is that on the front passager side i keep hearing this clunk. It only really happens when i go over bumps other than that i dont really hear it. The back passager one did for a short time after i put them on but then stopped. Can anybody help me on this?
Old Jan 20, 2004 | 05:49 PM
The_Todd's Avatar
Farts in the shower
Default Re: Coilover Noise. (H22SiRaccord)
Its probably your strut making the noise due to compressed status....oems will last for a bit but you will have to get better shocks/struts.
Old Jan 20, 2004 | 06:00 PM
So if i was to get new struts and shocks it would solve the problem?
Old Jan 20, 2004 | 06:03 PM
jwogen1's Avatar
Default Re: (H22SiRaccord)
it will definitely help, and i have also heard the clunk may come from the rear spring coils touching a bit.....just something i heard through the vine mang
Old Jan 20, 2004 | 06:08 PM
jwogen1's Avatar
not to get off track here, but what did you pay for those coilovers? with install?
Old Jan 20, 2004 | 07:03 PM
brads94accord's Avatar
mine did the same thing when i lowered it on stock shocks at first. it will go away when you replace the shocks with some aftermarket ones
Old Jan 20, 2004 | 08:22 PM
Default Re: Coilover Noise. (jwogen1)
The coilovers were 50 dollars from a friend. The Max speed coilovers retail for 250. I installed them myself so hard to say what it would cost for the labor to install them. Took me about 5 hours to install. Main reason it took so long is i ran into problems.
Old Jan 20, 2004 | 08:39 PM
91according's Avatar
it does the same thing on my accord i have maxspeed and it does it when i go over bumps it might be the strut but i doubt it.. to me it seems as if the coilover is almost jumoing around in a way and just makes a loud noise but all cars are diffrent and i have mine all the way down and it happens in the rear
Old Jan 20, 2004 | 09:14 PM
Yeah i have been told it is just moving around and as long as my car doesnt jerk hard to either side i will be fine. Anyway it is just reallly really annoying so i just turn up the radio.
Old Jan 21, 2004 | 05:34 AM
DrunkNRacer's Avatar
Maxspeed are cheap coilovers man.. dont expect a quality ride nor a quality sound from them. It sucks you have to worry about them "clunking" around. It could be because theres alot of play between the spring and the struts.. I couldn't tell ya because every car I have driven I put in springs w/ struts-shocks at the same time (its more labor effective that way).
Old Jan 21, 2004 | 10:17 AM
Blkblurr's Avatar
Default Re: (DrunkNRacer)
The problem is being caused by not having the coils of the spring wrapped where it sits on the strut. There is a metal to metal contact that will bang around when you go over a bump. The factory springs have a softer coating on them so that this does not happen. I am sure this is the problem because I have had it on my 2000 Accord coupe after the springs were changed. I simply pulled them apart and wrapped the bottom coil with electrical tape and no more noise. Hope this helps
Old Jan 22, 2004 | 07:30 PM
I will try that going to rip the front apart tom. and look b/c it worries me alot. I dont think having loud noise like that when i drive.
toshko321
49
Sep 8, 2009 04:47 PM
krzydc4
Suspension & Brakes
Jun 23, 2009 07:57 PM
phoQ
Mar 22, 2005 03:21 AM
CivHatchH22
Mar 12, 2004 01:21 PM
-iLLuZioN-B18C1
Aug 11, 2003 02:42 PM
