what does it take to make todas spec b work?
spec b on b18c, what is required to make it run...what valvetrain did you guys use?
did you upgrade the injectors or fuel pump?
thanks for any info!
my friend installed the spec b's with the type R springs, and stock valves. not sure about the fuel though, i'd be interested in hearing if you do need mods there too.
you should be able to handle fuel with a b&m fpr up'd to 50psi and a VAFC to fine tune and control vtec xover. Most people upgrade to bigger injectors but I dont' think they are necessary.
jeremy.
Sep 29, 2003 05:35 PM
