To buy this or not to buy this?
Why are you buying the kit? Lowering your teg? I read a GOOD thread a while back stating if lowering, a camber kit really isn't necessary, just a good alignment to set toe back to factory settings.
I used Velox camber kit, its only adjustable to 2 settings, but i lowered my 95 2 1/4 inch and it seemed to do just fine. I have also heard that a good alignment is all you need but remember be safe cuz tires are a bitch to replace. I would just play it safe.
I've had those same ebay kits for 3 years, on two different tegs...
I used to jump my old RS off the ground 6 inches with my hydros with them intsalled, and they are still in mint shape...
Never even lubed them since i put them in, and they are still strong as ever.
There are better quality kits, but these work great . I give 'em a
sounds good. I think i will get them then. Yes i am lowering my car probably 2 inches or more and i want the camber to be straight because i just bought a brand new set of tires. I don't want to have to go and buy another set because of bad camber. I just want to do it all right. I am buying a set of ingalls for the rear but the front ones are twice as much as these. So i looked at these and they almost look like the ingalls so i was like hmm why don't i ask the board and see what they think. Thanks for the info.
Contender25
Aug 5, 2006 11:18 AM
jArceo
Mar 21, 2005 07:22 PM
