Did type S motors have bigger LMAs to accept the bigger lift of the Type S cams?
Old Jan 20, 2004 | 04:52 PM
Soda Popinski's Avatar
Default Did type S motors have bigger LMAs to accept the bigger lift of the Type S cams?
Im just wondering cause i dont want to throw in some high lift cams in my jdm h22 and have problem with its LMAs.
Old Jan 20, 2004 | 05:01 PM
Fly1865's Avatar
Default Re: Did type S motors have bigger LMAs to accept the bigger lift of the Type S cams? (BeeBeeOne)
Your stock ones should be fine, the only replacements i heard of that are good for the H22 is the Type-R ones.
Old Jan 20, 2004 | 05:04 PM
Default Re: Did type S motors have bigger LMAs to accept the bigger lift of the Type S cams? (Fly1865)
Type R ones could swap into an h22? I know brad from RLZ could modify your stock ones to handle higher lift. But wat im trying to see if the stock ones would do.
Old Jan 20, 2004 | 06:21 PM
JDogg's Avatar
h22 lma = itr lma
Old Jan 20, 2004 | 07:25 PM
SiR EJ8's Avatar
what is lma?
Old Jan 20, 2004 | 09:21 PM
speedracer9k's Avatar
the LMA's are your Lost Motion Assemblies (SP?)
Old Jan 21, 2004 | 10:40 AM
LudeyKrus's Avatar
What exactly do the LMA's do?
Oh, and I heard the ITR LMA's have to have a certain width washer to act as a shim.
Old Jan 21, 2004 | 10:43 AM
Fly1865's Avatar
Default Re: (LudeyKrus)
Thats the Type-R guys using the H22 LMA. Cause the H22 is shorter in the Type-R motor so they have to shim it up. I just read that somewhere.
Old Jan 25, 2004 | 02:54 PM
aeolus's Avatar
Default Re: (Fly1865)
https://honda-tech.com/zerothread?id=566420
ground_shaking
Feb 20, 2009 09:29 AM
c1v1c98
Oct 14, 2008 01:52 PM
SuShiBoiiii
Aug 9, 2007 07:24 PM
Chalupa R
Jun 8, 2002 08:21 AM
