Should I change my gasket???
Old Oct 2, 2001 | 07:10 AM
KamikazeTypeR's Avatar
New User
Default Should I change my gasket???
I'm about to put my JDM 4-1 header on my R in about a week and was wondering if I need a new exhaust manifold gasket....My brother says I can re-use my old gasket...My car currently has 22,XXX miles on it...Any opinion/advice is appreciated...thank you
Old Oct 2, 2001 | 07:21 AM
onyx00's Avatar
Default Re: Should I change my gasket??? (KamikazeTypeR)
I reused mine but I only had 8000 miles. It is a metal gaskets so I think it should should be fine. Mike at IPS (www.ipsracing.com) should have them available if you do need a replacement.
Old Oct 2, 2001 | 07:48 AM
Rhetoric's Avatar
Would it be any help to spray copper spray on a stock metal gasket? Or are those only for the copper gaskets?
Old Oct 2, 2001 | 09:29 AM
Rory Breaker's Avatar
Default Re: Should I change my gasket??? (G S R)
In most cases you can reuse the gasket. Just check it out when you take it off. If you need a new gasket, run to the dealer. You should be fine though.
didyouhearthat
Nov 10, 2013 08:11 PM
krysted9354
Dec 17, 2008 05:45 PM
jonnybadboi9
May 8, 2008 06:16 PM
copperfox
Jul 25, 2004 04:32 PM
Ferrell
Jun 11, 2002 09:55 PM
