How to adjust timing to help pass smog?
Old Jan 20, 2004 | 03:35 PM
haophat's Avatar
Default How to adjust timing to help pass smog?
I have heard that if I adjust the timing on my engine to like 10 deg after TDC it will help me pass the smog test? is this ture and can you tell me how to do that on my teg? its a 0 teg with the stock b18c engine. I kow how to adjust old chevy timing by spinning the dist but how do you do it on a b engine???
Old Jan 20, 2004 | 03:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How to adjust timing to help pass smog? (haophat)
same way, loosen the distributor and move it while monitoring timing w/ a timing light.
Old Jan 21, 2004 | 12:24 AM
96dc2's Avatar
Sorry to burst your bubble, but 14 is the lowest you can go. And they'll check it too. It's BTDC, ATDC.
Old Jan 21, 2004 | 08:30 PM
ejprimo's Avatar
Default Re: How to adjust timing to help pass smog? (96dc2)
if its a test only smog station, then they will check your timing and it has to be within 2 degrees of the stock setting.
methos713
Jul 28, 2008 08:51 AM
GsR-Freak
Apr 1, 2005 11:37 PM
vile10
13
Nov 8, 2004 09:17 PM
MIZIKETSK
Sep 16, 2003 08:13 AM
ITR#00-1077
May 21, 2002 01:03 PM
