Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket?
Old Jan 20, 2004 | 02:59 PM
IloveNewt's Avatar
Default Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket?
My wastegate gasket is always blowing in this one spot. Can i put some liquid gasket on the new gasket to ensure a better seal? Won't fugg up anything i hope....
Old Jan 20, 2004 | 03:01 PM
redboost10's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (MordecaiPSI)
from what ive read i think you should try not using a gasket
Old Jan 20, 2004 | 03:03 PM
IloveNewt's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (tgh99si)
i tired that...the leak is even worse.
Old Jan 20, 2004 | 03:07 PM
redboost10's Avatar
well im not sure but i would try some high temp silicone like rtv type stuff
Old Jan 20, 2004 | 03:13 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Get the turbonutics wastgate with the silver ring around the inside, mine has not ever blown it's been six months.
Old Jan 20, 2004 | 03:16 PM
rtype11's Avatar
sounds like something is warped, check for flatness of mating surfaces, you may need to get either or both flages straightened by milling. see iff you cant get someone to put an o-ring receiver groove on the wastegate or a gasket with oring in it.
Old Jan 20, 2004 | 03:27 PM
5thgencivic's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (HybridcivicLS-T)
I bought 2 of the good gaskets from ATP and am using them(one mani to wg, other wg to dump)
Old Jan 20, 2004 | 03:34 PM
Flamenco-T's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (5thgencivic)
yeah, check for straigness, I never use gasket and never leaks...sometimes the cheaper gasket casuse leaks than having no gaskets
stan
Old Jan 20, 2004 | 03:38 PM
Muckman's Avatar
Moderator in Chief
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (Flamenco-T)
Do you still need to use a gasket if your wastegate has a metal fire ring?
Old Jan 20, 2004 | 05:01 PM
b16ahybrid's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like something is warped, check for flatness of mating surfaces, you may need to get either or both flages straightened by milling. see iff you cant get someone to put an o-ring receiver groove on the wastegate or a gasket with oring in it.</TD></TR></TABLE>
yep sounds like one of the surfaces is warped. I'm not using a gasket (blew both tial gaskets) and am having no problem at all.
Old Jan 20, 2004 | 08:41 PM
IloveNewt's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (b16ahybrid)
NO leaks at all with no Gaskets? I mean when i didnt use a gasket it wasnt "that" bad. Just you could see some black areas around the manifold/wg where it was kinda seeping....
The manifodl is an SFP.
If you can visualize where the WG is and how its positioned.....it leaks right where they meet. on the edge. Just teh weight of the dumptob and the WG itself i guess makes it leak a bit. I really don't wanna take apart all the crap to get it milled....ill try some copper gasket stuff i got in the tool box first .
Old Jan 20, 2004 | 08:46 PM
TRE_'s Avatar
i kept blowing the same gaskets, turned out that the flange was warped... took the manifold off and grinded the flange down til it was perfectly even and put some high temp silicon on there and its fine now...
Old Jan 21, 2004 | 04:19 PM
b16ahybrid's Avatar
yep, no leaks at all.
I've ran that way for about a yean now.
Old Jan 21, 2004 | 04:55 PM
SlowTeg's Avatar
Simple fix. Just use rtv like you were originally thinking. I had the same problem you did and rtv worked perfectly. It lasted a good year for me till I had to just pull it off and redo the rtv because there was a tiny leak. The gaskets kept blowing for me as well. I checked the flange and it's very slightly warped, but it's not worth the time of getting it decked imo. Just use some rtv and ur good to go.
-Mike
Old Jan 21, 2004 | 05:09 PM
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (SlowTeg)
So the question is, should gaskets be used? Or is it meant to be run without if both surfaces are perfectly flat?
92HB_HB's Avatar
can RTV withstand the heat from the manifold?? it does get quite hot...
Old Jan 21, 2004 | 05:26 PM
SlowTeg's Avatar
Gaskets are always "supposed" to be used imo. It's just that sometimes you can get away w/o using them...
-Mike
Old Jan 21, 2004 | 05:27 PM
SlowTeg's Avatar
Default Re: Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket? (92HB_HB)
RTV can EASILY withstand the heat.. If you read my post, mine's been on for over a year.. I forget what the rated temp for rtv is, but it's pretty high. It's not uncommon to use rtv as exhaust gaskets.
-Mike
Old Jan 21, 2004 | 06:15 PM
IloveNewt's Avatar
I ended up using some copper silcone liquid gasket stuff. Thign said it could withstand 700 degrees....i made a coupel runs it seems to be holdin aiight...we'll see.
Old Jan 21, 2004 | 06:20 PM
teal EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">I ended up using some copper silcone liquid gasket stuff. Thign said it could withstand 700 degrees....i made a coupel runs it seems to be holdin aiight...we'll see.</TD></TR></TABLE>
I blew mine out and used the same stuff. It seems to hold up pretty well so far. (5 months)
Kev-turboEJ1
Nov 28, 2006 12:49 PM
hondaeg8
May 31, 2006 12:56 AM
Tactic$
Oct 11, 2005 04:02 PM
XBoostedAccordX
Oct 18, 2003 09:31 PM
SpeedMonkeyRacing
Oct 9, 2003 12:33 PM
