need to rebuild my motor again. What do i need.
Old Oct 2, 2001 | 06:53 AM
98TypeR's Avatar
Default need to rebuild my motor again. What do i need.
My rings aren't sitting properly. I didn't gap them right. My bad. Anyways, The car has put 2500 miles since then.
What gaskets are reusable and what need to be replaced. (eg oil pan, oil seals, head gasket, head bolts,...?)
Old Oct 2, 2001 | 07:59 AM
FAST94GSR's Avatar
New User
Default Re: need to rebuild my motor again. What do i need. (98TypeR)
Once a gasket is compressed it is no longer reusable. such as headgasket. those paper gaskets you can reuse but more than likely they rip during disassemble so just plan on buying new gaskets all around
Old Oct 2, 2001 | 08:34 AM
98TypeR's Avatar
Default Re: need to rebuild my motor again. What do i need. (FAST94GSR)
i've used old gaskets before and hadn't had a problem. of course it was without the car being started.
Old Oct 2, 2001 | 08:43 AM
B18C-EJ1
Guest
Posts: n/a
I reuse just about every gasket. 2500 miles is nothing. You may have to replace your headgasket if it seperates when you take the head off.
What pistons are you running?
Old Oct 5, 2001 | 11:17 AM
98TypeR's Avatar
Default Re: need to rebuild my motor again. What do i need. (B18C-EJ1)
running toda pistons. no one is really clear about the specs on these. Most people say stock clearances though.
2stroke1971
11
Mar 27, 2015 03:02 AM
xrated1
Jul 13, 2009 07:49 PM
crxstylin
May 20, 2008 07:40 AM
G2turbo_terror
Jan 12, 2003 07:34 PM
Chuji
Jul 5, 2002 10:10 PM
