Car ran out of gas w/half a tank???
Old Jan 20, 2004 | 02:20 PM
space-tuna's Avatar
Default Car ran out of gas w/half a tank???
Just recently I installed a new in tank fuel pump, along w/ a motor swap and turbo setup. At half tank my car started sputtering and I ran out of gas. I filled it up and it ran fine, when I got to half tank the same thing happened again today. When the fuel gets low I can hear the fuel sloshing around when I go around corners as well. Any input???
Old Jan 20, 2004 | 02:21 PM
space-tuna's Avatar
Default Re: Car ran out of gas w/half a tank??? (space-tuna)
Nothing is wrong with the gauge either. It took ten dollars worth of gas to fill a half tank today w/premium.
Old Jan 20, 2004 | 02:22 PM
rtype11's Avatar
did you install the pickup correctly????? ps if your pump tried pumping and there was no gas it might be cooked.
Old Jan 20, 2004 | 02:45 PM
space-tuna's Avatar
Default Re: Car ran out of gas w/half a tank??? (rtype11)
Well it runs fine now that I've filled it up w/gas so I doubt it's been cooked. Where exactly is the pickup??
Old Jan 20, 2004 | 02:51 PM
rtype11's Avatar
well i mean maybe it didnt reach down past halfway, the pickup is basically the intake part of the pump, I was led to believe it wasnt submerged in gas tank all the way.
Old Jan 20, 2004 | 03:55 PM
Muckman's Avatar
Moderator in Chief
Walbro? Ive read some ppl have had problems with the walbro and low fuel but I dont with mine.
Old Jan 20, 2004 | 03:58 PM
InTeGrA B18b1's Avatar
Default Re: Car ran out of gas w/half a tank??? (Muckman)
you probaly got the 255 lph walbro pump. my cousins died just under half a tank. keep it full.
Old Jan 21, 2004 | 07:18 AM
space-tuna's Avatar
Default Re: Car ran out of gas w/half a tank??? (InTeGrA B18b1)
WTF??? It is a walboro and I take some long drives so I can't use only half a tank. Anyone have walboro's phone number??
Old Jan 21, 2004 | 07:24 AM
PM-Performance's Avatar
ive never heard of that before, i have ran mine empty many many many times and no probs.
Old Jan 21, 2004 | 07:36 AM
platinum00's Avatar
Default Re: Car ran out of gas w/half a tank??? (itr206)
i have a walboro and have no issues
i run mine bone dry
sounds like you got a bad pump
platinum.
Old Jan 21, 2004 | 08:01 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Car ran out of gas w/half a tank??? (platinum00)
It sounds like you attached it upside down, actually. I've installed two or three of them personally and none of them has ever experienced any kind of problem.
If it was upside down, obviously, your tank would stop supplying gas to the pickup much sooner than "empty".
Old Jan 21, 2004 | 08:52 AM
dwn-shift's Avatar
Default Re: Car ran out of gas w/half a tank??? (Archidictus)
Check to see if the pickup didnt fall off...
Old Jan 27, 2004 | 11:29 AM
space-tuna's Avatar
Default Re: Car ran out of gas w/half a tank??? (dwn-shift)
Figured it out. The pickup that comes w/ the wahlboro is too small and sticks up at an odd angle so that it isn't fully submerged. Put the stock pickup on it and it works fine.
Old Jan 27, 2004 | 12:09 PM
TOFU.man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by space-tuna &raquo;</TD></TR><TR><TD CLASS="quote">Figured it out. The pickup that comes w/ the wahlboro is too small and sticks up at an odd angle so that it isn't fully submerged. Put the stock pickup on it and it works fine. </TD></TR></TABLE>
Yep Yep.
I Like Hondas
Dec 2, 2012 11:55 PM
dephtone
24
May 17, 2011 05:19 AM
uberEFtuner
May 23, 2010 10:59 AM
eL
37
Oct 20, 2005 03:27 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
