Pinging Noise ran low on oil (Please HelP)
Old Jan 20, 2004 | 01:44 PM
ludeboy555's Avatar
Default Pinging Noise ran low on oil (Please HelP)
I had an oil leak. Loss alot of oil. I ran the car pretty hard that night. I was on the freeway and ran my homie, then all of a sudden the check engine light came on. Drove home checked the oil it was hella low. Added oil, then the next day saw a small puddle of oil. Fixed the oil leak, took off the oil pan and got a new gasket. Also check my crankshft while I was under there and didn't see any scratches or anything weird. Just making a low pinging noise. Know it is hard to tell you about the noise, but please help. Could it be my piston? What could it be or how can I get rid of this.
Old Jan 20, 2004 | 02:02 PM
PrecisionH23a's Avatar
Default Re: Pinging Noise ran low on oil (ludeboy555)
Low pinging meaning like a low knock knock knock that increases as your RPM's increase? If so, you spun a bearing. Did you notice any shavings in your oil pan?
Old Jan 20, 2004 | 02:10 PM
ludeboy555's Avatar
Default Re: Pinging Noise ran low on oil (GudeH23a)
That knock knock knock, it goes up as RPM increase but not as bad as idle. Oil pan was so dirty that I proably wouldn't have notice. If I spun a bearing is that pretty much a rebuild.
Old Jan 20, 2004 | 07:45 PM
ludeboy555's Avatar
Default Re: Pinging Noise ran low on oil (jz)
If I spun a bearing is it still cool to drive around or is it something I can drive on?
Old Jan 21, 2004 | 04:42 AM
pentaq's Avatar
It's cool only when you want to kill the block. Now you may have a chance to rescue the engine.
Old Jan 21, 2004 | 05:07 AM
Timmy Joe's Avatar
If you can drop the pan again you should be able to disconnect the rods from the crank then make a close inspection of the rod bearings. DO NOT PULL THE PISTON WITH OUT THE HEAD OFF OR EVEN ATTEMPT IT. You may be able to get a way with just replacing the bearings. I make this sound simple but it can be a bitch. Still cheaper then paying somebody. then plastigage the bearings before installing the new ones that should help with any scarring that took place. There you go a poor mans low end job. this may buy you some time before having to tear in to it for an actually full rebuild.
Old Jan 21, 2004 | 08:53 AM
thehondaguru's Avatar
Yeah what he said^^^^^^^
Do not drive it if you want the motor to be usable for a rebuild.
Old Jan 21, 2004 | 10:55 AM
ludeboy555's Avatar
Default Re: (95 lude)
Fo sho. Thanks for the help guys. Been driving on it, but not too far. The car runs fine thou. Damn this just sucks. Was gonna buy me SMSP header, but guess not. Thanks again for the help guys.
ramboPandA
Sep 17, 2018 02:25 PM
raverx3m
18
Jul 31, 2012 10:11 AM
GoldCoin
Honda S2000
16
Apr 23, 2011 07:35 PM
Toe_Knee
Sep 30, 2008 08:42 PM
GDR888
11
May 28, 2007 11:36 AM
