What does this pully do?
Old Jan 20, 2004 | 12:52 PM
StatGSR's Avatar
Default What does this pully do?
well after i heard some rattling i found that there was a loose pully and arm bouncing around with all my belts and pullys, well we pulled it out and kept it out and didnt think much of it since it looked like all it was was a guide of some sort.
Anyway, my alternator belt just fell of and im curious if that maybe is because that pully hasnt been in for a while. here is the pully im talking about, or atleast im pretty sure its the pully i have pulled out, im not 100% sure.
any information is appreciated.
Old Jan 20, 2004 | 01:12 PM
Four Door LS VTEC's Avatar
Default Re: What does this pully do? (StatGSR)
idler pulley...used to put tension on a belt and keep it in place.
whether or not that is specifically for the alternator belt I forget.
Old Jan 20, 2004 | 01:13 PM
Toda Built's Avatar
I cant see any pic... but from what it sounds like you took out an tensioner pulley of some sort.
:edit: now I can see the pic. It looks like the tensioner pulley for the power steering or the AC
Old Jan 20, 2004 | 01:32 PM
mr.beeks's Avatar
Default Re: What does this pully do? (Toda Built)
its a tensioner pulley for your AC compressor
if you dont have AC remove it....
Old Jan 20, 2004 | 01:53 PM
StatGSR's Avatar
Default Re: What does this pully do? (mr.beeks)
alright thanks, but since its winter and 13 degrees out, its not all that important right now, but yea, if my A/C sux this summer, i will know why. thanks.
Old Jan 20, 2004 | 02:34 PM
agrn93ls's Avatar
if you removed a pulley and things still work it can only be the A/C idler pulley there are only 5 pullies on a integra. 1.Crank pulley(that is attached to the engine) 2.Alt pulley (attached to the alternator) 3.Power steering pump pulley ( it is attached to the p/s pump). 4.A/C compressor pulley (attached to the compressor) and of those 4 none should be able to be simply removed. and last the one it should be, if not and you dont know the difference dont ever open your hood again. 5.A/C idler pulley it is the one circled in the above pic and bolts on by a pivoting arm to the ac compressor braket, it tensions the A/C belt since the A/C compressor is mounted solid, the simplest way is to see what belt is missing.
Old Jan 20, 2004 | 03:46 PM
StatGSR's Avatar
Default Re: What does this pully do? (agrn93ls)
my A/C belt isnt missing, none of my belts are missing, just that my alternator belt fell off a couple days ago, but that clearly now has nothing to do with this other pully that fell off a long time ago. i was always pretty confident that this pully wasnt all that important, but i just thought i would check. anyway, thanks for all the help guys.
Old Jan 20, 2004 | 05:29 PM
deepgreengsr's Avatar
Gurrantee without that your AC will not blow cold air.
Old Jan 20, 2004 | 06:53 PM
StatGSR's Avatar
Default Re: What does this pully do? (deepgreengsr)
aight well i got like 6 months till i need AC anyway, but thanks for the warning.
Old Jan 20, 2004 | 06:58 PM
XtremeCarTuner's Avatar
I'd say remove it.... save yourself some decent power gains if ya know what i'm talkin about..
Old Jan 20, 2004 | 07:19 PM
StatGSR's Avatar
Default Re: (XtremeCarTuner)
yea, i may remove it, i will find out if i really need it this summer.
patrickstar
Feb 26, 2009 09:34 AM
ubermoc
Feb 9, 2008 09:05 AM
dotay
Dec 30, 2006 01:35 PM
Coroner
Sep 20, 2006 05:37 PM
Import_Dumbass
10
May 21, 2006 03:59 PM
