Bad Wiring?
Old Jan 20, 2004 | 11:52 AM
nightryder21's Avatar
Default Bad Wiring?
alright i got a 94 gsr. i have a sony head unit and audiobahn components up front and audiobahn 6x9 in the rear deck. every once in a while the sound gives out. the radio and cd player keep playing just fine i just can't hear anything. then when i shift or go over a bump the sound sometimes comes back on. when my car is still the sound is perfect. how can fix this or is their a way to rewire all the audio wires. any advice will help thanx.
Old Jan 20, 2004 | 01:35 PM
PupaScoopa's Avatar
Default Re: Bad Wiring? (nightryder21)
It sounds like there's either a short (some wires are touching, possible at the speaker and not necessarily behind the head unit) or a loose wire... more likely the former.
If that checks out ok, there may be a problem in the head unit. Pull it out and tap/bounce it around a little to try to reproduce normal car motion.
Old Jan 21, 2004 | 08:00 PM
Default Re: Bad Wiring? (Optionaloem)
wierd cause circuit city installed my speakers. i have a factory harness. its annoying the **** out of me!!!!
Old Jan 21, 2004 | 08:51 PM
Traction's Avatar
bring that **** back to cirvuit city if it was installed recently, there always good about fixing screw ups
Old Jan 24, 2004 | 11:20 AM
Default Re: Bad Wiring? (StealthEF)
naw its been like a year by now.
Old Jan 24, 2004 | 11:21 AM
naw its been like a year by now. i did fix my antennea a few weeks back before it started happening. could that have caused it?
Old Jan 28, 2004 | 01:59 PM
ok i covered every exposed wire i have in my car. so far it seems to have worked. nut i still have a problem. my driver side tweeter dosen't work. i've switched tweeters, crossovers, and wires and still no sound from my tweeter. has this happened to anybody else?
Old Jan 28, 2004 | 06:21 PM
seppuku's Avatar
check for bad soldering on the speakers as well...sometimes if they are pushed really hard, the heat can cause solder connections to become weak...make sure none of the wires on the speakers touching (the ones that run to the coil...that happened on my Girl Friends 10" Rockford Fosgate...it was the poor design of the Sub causing the wires to arc and short out the sub...eventually leading to destroying the amp.
Fantastic420
Audio / Security / Video
10
Oct 7, 2009 10:58 PM
little dx that could
Jul 28, 2008 05:49 PM
HtxPrelude2K
Nov 1, 2007 11:43 AM
cleofis
Jun 8, 2004 10:03 AM
slowacura
11
Mar 8, 2004 11:50 AM
