94 b18b in a 96 ek. which motor mounts
im about to sell my motor to a guy with a 96 civic. which mounts does he use??? i know he will need an obd2-1 ecu harness. anything else??
Thanks
Burke
Thanks
Burke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg »</TD></TR><TR><TD CLASS="quote">99 SI rear L-bracket
99 SI driver's side post mount + studs/nuts</TD></TR></TABLE>
So in the rear, a bracket is needed, but on the driver side, do you need a rubber mount or a bracket? or both?
It's best if you use all the mounts from the EBP SI, it's less confusing that way.
but if you don't have all of them, you need at least the rear L-bracket. The stock (d16) EK driver's side mount can be used on a b-series also. a b-series tranny mount will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe »</TD></TR><TR><TD CLASS="quote">i thought that with the 96+ civics, you only needed the rear bracket to swap a motor in? </TD></TR></TABLE>
Well, the problem with the driver side mount as far as the integra engines goes (LS/GSR/and ITR), is that all integra engines use a 3-post block mount (black cast iron mount). This mount needs to be changed either to an 99-00 Si mount or 92-95 B16A mount, as these mounts use a 2-post cast iron mount which is compatible with the 96-00 civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Katman always come up with some tight a$$ diagrams with pictures and ****.
(gay wink)</TD></TR></TABLE>Katman's GAY?
J/K.
J/K.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg »</TD></TR><TR><TD CLASS="quote">Katman's GAY?
J/K.</TD></TR></TABLE>
no. the wink icon is gay not me (notice the smiley is winking with its right eye)
J/K.</TD></TR></TABLE>no. the wink icon is gay not me (notice the smiley is winking with its right eye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlvlhatch »</TD></TR><TR><TD CLASS="quote">where are those diagrams from?? i want to look at more.</TD></TR></TABLE>
They're Helms diagrams I've scanned and modified inPhotosho. I have a few more of them for various tech related things, you can snoop my tech directories here :
http://ff-squad.com/tech
GrimeyAssLos
11
Feb 27, 2012 09:56 AM
mugen12_35sec
Jan 22, 2009 11:00 AM
asocallocal
Apr 11, 2008 10:28 PM
ApexiChild
Nov 29, 2004 02:13 PM
