94 Accord
Old Jan 20, 2004 | 10:53 AM
DrewQ1's Avatar
Default 94 Accord
Whats a good chip to put in my car and how much perfomance would i get?
by the way, my car stock, but i plan on adding CAI, exhaust and headers.
Modified by DrewQ1 at 3:08 AM 1/21/2004
Old Jan 20, 2004 | 10:55 AM
knowtomorrow3001's Avatar
Default Re: 94 Accord (DrewQ1)
hondata
Old Jan 20, 2004 | 10:56 AM
The_Todd's Avatar
Farts in the shower
Hondata if your running some serious mods (turbo etc) or AEM I have heard makes a decent ecu upgrade.....let us know.
Old Jan 20, 2004 | 10:59 AM
DrewQ1's Avatar
Default Re: 94 Accord (VRDrvr)
how much would it go for and how much of a gain would i get?
Old Jan 20, 2004 | 11:04 AM
The_Todd's Avatar
Farts in the shower
I know most of them they have a learning curve (like your stock ecu) but with less restrictions, I think the hondata one you program yourself. I hve seen others where you send them your ecu and they calibrate a new one again with less restrictions, I would say 10-20 hp and the like for tq.
Old Jan 20, 2004 | 11:37 AM
jwogen1's Avatar
i also heard good things about hondata. i researched the JET Performance one for the 94 Accord and it seemed to have some good gains for hp/trq. it did require sending it away and being programmed for what was currently done to your car and for future stuff. place i talked with said my car would only be down for like 2 days, and it only cost around $300. not sure how this would effect the possiblity of an engine swap.
Old Jan 20, 2004 | 11:38 AM
jwogen1's Avatar
Default Re: 94 Accord (jwogen1)
maybe you guys will know, but I am assuming they cant be reprogrammed after this or maybe they can?
Old Jan 20, 2004 | 11:44 AM
The_Todd's Avatar
Farts in the shower
I would assume since they can program them they should be able to reprogram them.....I have heard about JET too...they ship it out overnight, the only down time is like a day not bad IMO.
Old Jan 20, 2004 | 12:12 PM
jwogen1's Avatar
i have been contemplating it myself...have to remove the old one which is under passengers side floorboard. not sure how to approach that one
Old Jan 20, 2004 | 12:19 PM
The_Todd's Avatar
Farts in the shower
Just pull up the carpet (there should be tabs) and the there should be a holder that holds both your ecu and tcu unplug and your money......at least on my 4th gen its like that, should be the same on yours.
Old Jan 20, 2004 | 01:46 PM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Just pull up the carpet (there should be tabs) and the there should be a holder that holds both your ecu and tcu unplug and your money......at least on my 4th gen its like that, should be the same on yours. </TD></TR></TABLE>
for 5th's its same place under carpet, but it has a few screws u need to take out, remove the metal bracket thing, and ur set... i used a long neck socket to get the screws out, its i na bad angle to use a plier... gluck.
Old Jan 20, 2004 | 03:22 PM
jwogen1's Avatar
Default Re: 94 Accord (Mike813)
no problems with the floor carpet going back properly or anything?
Old Jan 20, 2004 | 06:44 PM
DrewQ1's Avatar
where can i find hondata and how does the chip go far?
Old Jan 20, 2004 | 06:45 PM
The_Todd's Avatar
Farts in the shower
http://www.hondata.com
http://www.jet.com
Those are for the hondata and the jet chips.
Old Jan 20, 2004 | 07:01 PM
DrewQ1's Avatar
i'm lookin at the website but i cant find anything for just a chip.I see systems and ecu's . I'm not lookin to replace the computer. Just a chip,or maybe i'm lookin at the wrong section.
Old Jan 20, 2004 | 07:47 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">i'm lookin at the website but i cant find anything for just a chip.I see systems and ecu's . I'm not lookin to replace the computer. Just a chip,or maybe i'm lookin at the wrong section.</TD></TR></TABLE>
you just have to realize there isnt a good chop availble, this is not VW or wrx bro.
anyway, think of it this way, would a chip work on your car and work on mine? and would the same chip work on turbo or bottle fed car? there's no universal application here.
Vafc for the mildy mod. honda
hondata for the turbo or baller
gosu08
Sep 2, 2006 02:09 PM
1fastvtec
Jan 20, 2005 07:54 PM
2000Accord5sp
May 16, 2003 12:01 PM
accord ex
Jun 19, 2002 07:19 PM
accordfreak
Jan 4, 2002 12:58 PM
