Which way is ON for fuel? Pic of the switch inside....
Old Jan 20, 2004 | 09:30 AM
Fuster_Cluck's Avatar
Default Which way is ON for fuel? Pic of the switch inside....
I tried cranking it a couple times and it turns over but not starting.
Is the switch suppose to be pointing down or up? In the position shown it's OFF!
Thanks for helping out a nQQb!
I want to ride this thing
75 or 76 Honda CB200T......Old school biatch
Old Jan 20, 2004 | 09:32 AM
diewX3's Avatar
I believe pulling the fuel valve down turns it on and up is reserve. Can any old school rider correct me
Old Jan 20, 2004 | 10:05 AM
tonydatyga's Avatar
Default Re: Which way is ON for fuel? Pic of the switch inside.... (Hybrid93Hatch)
It's not terribly standard but either one will deliver fuel...
Old Jan 20, 2004 | 10:11 AM
Default Re: Which way is ON for fuel? Pic of the switch inside.... (tonydatyga)
I tried down and it turns but the mother f**ker won't start. Damn I am pissed off now. Day off from work and I just want to ride around the block to get familiar with the bike. Can't do it because I can't start the f**kin thing *PISSED OFF*
Old Jan 20, 2004 | 01:47 PM
slammed EG's Avatar
Ride it down a hill at 10-15mph and pop it into first without the clutch, if it doesn't start then, it's not going to.
Old Jan 20, 2004 | 01:50 PM
BoostedSi's Avatar
Default Re: (slammed EG)
I have to spray carbeurator cleaner into the side of my ex500 to get it to start. Maybe that would work. It also points down for the fuel to be "ON" on it.
Old Jan 20, 2004 | 02:48 PM
Default Re: (BoostedSi)
Thanks for all the feedback so far. My father and I did the push start method which I believe he was in 2nd gear. Got it started but the bike did not seem like it was making much power. Also, with the switch pointing down (main fuel tank) gas will drip quickly out of the circled hose. Doesn't matter the position of the choke lever, still pours out:
Old Jan 20, 2004 | 05:27 PM
BoostedSi's Avatar
Default Re: (Hybrid93Hatch)
this is where i put it in. Its on the right side of the bike. I just spray it in for a few secs.
Hope that helps and good luck!
equ117
Aug 7, 2008 06:53 PM
dyu626
Honda Motorcycles
26
Oct 3, 2007 06:27 AM
killaj12
Audio / Security / Video
Mar 30, 2005 06:26 PM
cyzum
Jun 2, 2002 07:54 PM
